Best way to fit 33s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arkansas30, Nov 13, 2014.
  1. Nov 16, 2014 at 5:22 AM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    Ok will do after my morning hunt ;)
  2. Nov 16, 2014 at 7:45 AM
    Arkansas30
    Arkansas30 [OP] Well-Known Member
    Conroe, Tx
    2014 Titan Pro4x
    Still my question is the back shocks having a the right amount of travel.
  3. Nov 16, 2014 at 9:41 AM
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    The rim you chose will also make a big difference in how the tire will be in the wheel well (rubbing or not). Backspace, width, offset are important to consider
  4. Nov 16, 2014 at 10:20 AM
    BradyT88
    BradyT88 Well-Known Member
    I may have missed it, but what exactly do you plan on doing with your truck before TW goes spending all your money for you? haha
    If you will just see pavement then I wouldn't break the bank on stuff.
    If you will be going offroad, what do you plan on doing offroad exactly? That will determine what direction you want to go.
    You can check out Down South Motorsports's website for some rear shocks that range from 8-10" of travel that work on the rear of our Tacomas.
  5. Nov 16, 2014 at 11:08 AM
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    I am stock now love my trd wheels. Right now it's just a stock baja. I like to run a bigger tire but still be able to move and no rubbing .
  6. Nov 16, 2014 at 11:24 AM
    BradyT88
    Once again, move is pretty vague. If you are just running on the streets or basic fireroads you can do a 3" lift and practically clear 35's.
    If you are out mobbing the desert or rock crawling clearing takes on a much more aggressive meaning. I have beat the shit out of my firewall and inner fenders and don't a good amount of trimming and my 33's still rub a little at full stuff. A street truck will never see full stuff though.
    http://youtu.be/eOmNokWmmJA
    Swb_05 and theolee like this.
  7. Nov 16, 2014 at 11:29 AM
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    Ok so 33s and my trd wheels 5 100 up front. Now out back I need add a leaf or block?
  8. Nov 16, 2014 at 11:33 AM
    BradyT88
    I would get an AAL over a block, but personally I would look into a complete leaf pack if you need better performance.
  9. Nov 16, 2014 at 12:22 PM
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    I don't plan on jumping dunes since I do live in Arkansas. But I do want the truck to be able to move like it should. I have read where guys are running 255s on stock baja trim.
  10. Nov 16, 2014 at 3:01 PM
    xtyfighterx
    Ty
    Doesnt the trd baja come with. 2.5in Lift?
  11. Nov 16, 2014 at 3:03 PM
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    Yes but 2.5 isn't anuff for 285s people have ran 255s.i think it's the width of the tire.
  12. Nov 16, 2014 at 3:05 PM
    xtyfighterx
    Ty
    I have a 2in lift and 285's I guess if you don't want to trim a little.
  13. Nov 16, 2014 at 3:07 PM
    xtyfighterx
    Ty
    If you have 17s you could run a 275 series tire but u think the baja has 16s
  14. Nov 16, 2014 at 3:14 PM
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    Have 16s the trd wheels.
  15. Nov 16, 2014 at 3:24 PM
    #35
    bzzr2
    bzzr2 Well-Known Member
    just put some 255's on there and don't worry about the trimming and cab mount chopping. it is that simple. some nice cooper st maxx's or toyo mt's. or put 285's and do the cutting.
    for the rear lift if you never carry weight you can get away with a block and call it good. ride will remain as stock. ppl piss on the blocks all the time on this site, true they are not the best but your truck won't explode like ppl may post here saying all kinds bs. as for shocks you can run something longer like the ome rears or the skyjacker h7045. i ran the skyjackers with my dakar leaf pack. i initially had a block with the 3 leaf pack, then i snapped a leaf and upgraded. anyway if you want a firmer ride out of the back of the truck an add a leaf is better. of course as already mentioned a full leaf pack is always best.
  16. Nov 16, 2014 at 3:32 PM
    #36
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    So ur saying 285s will fit with how I am set up now? What would I have to trim.
  17. Nov 16, 2014 at 3:34 PM
    #37
    xtyfighterx
    Ty
    Remove front mud flap and there is a piece of the fender liner that hangs down u have to trim really simple every setup us different tho
  18. Nov 16, 2014 at 3:34 PM
    #38
    xtyfighterx
    Ty
    And depending on the wheel backspacing you may need a spacer or different wheels idk the specs on baja wheels
  19. Nov 16, 2014 at 3:37 PM
    #39
    Arkansas30
    Conroe, Tx
    2014 Titan Pro4x
    Don't have mud flaps.
  20. Nov 16, 2014 at 3:41 PM
    #40
    BradyT88
    For 285's I think you can't really get around not trimming the cab mount and you're probably have to trim the flares some.
    With my 255's on wider wheels I don't rub the cab mount and only had to do minimal trimming.
    255's are taller too (though not significantly).
