Best way to Fluid Film rockers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SR-71A, Jul 30, 2023.
  1. Jul 30, 2023 at 8:06 AM
    SR-71A
    SR-71A [OP] Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Obviously lots of people talk about protecting the frame when living in the rust belt. But I never see anyone talk about applying anything inside the rockers?
    What's the best way to get in there to apply this stuff? I see a nine little rubber plugs looking up, do those provide enough access inside for the little 360* sprayer?
    Steelhead Bum likes this.
  2. Jul 30, 2023 at 8:09 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    :popcorn:
    I spray inside the dog legs and the drain holes in all the doors. Curious to see what others are doing.
    SR-71A[OP], Glenny and winkel like this.
  3. Jul 30, 2023 at 9:37 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I thought about doing that area by using something like corrosion x in an undercoating gun with 100lbs of pressure set on the compressor. I think that amount of pressure will make the corrosion X into a mist and you could probably get it pretty good from just one of those little holes with 2 or 3 burst.
  4. Jul 30, 2023 at 9:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Worthy a test. Very good product! If you do test this theory, please report back!
    Glenny and spitdog[QUOTED] like this.
  5. Jul 30, 2023 at 11:35 AM
    spitdog
    :thumbsup:
  6. Jul 30, 2023 at 3:16 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I put the little red tube on the can and spray up into the weep holes in the pinch seam and I've even removed the plugs and sprayed in there.
    Unlike the frame, I think one application would last for years since this area isn't blasted with water and debris while driving down the road.
    Like @Steelhead Bum said, I also spray up into the drain holes in my doors. I like to do it now, when it's really hot out so it will wick into all the little crevices. I even have to wipe off the outsides of my doors for a while afterwards because it wicks/creeps up the outsides of the door as it drains back out.
    In fact, I just ran a zip tie up into all of my door drain holes the other day to make sure nothing is clogged. All was good.
    In the doors and rockers, I also like to use Dollar General's WD-40 knock off. It's a little thicker than WD-40, but I think it wicks better than Fluid Film.
    tinker_troy, Torspd and Steelhead Bum like this.
  7. Jul 30, 2023 at 5:35 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    ShopStraw FS250 FlexStraw Aerosol Can Replacement Straws, Neon Green, 50", 2-Count https://a.co/d/7XuogkG
    fixnfly and Torspd like this.
  8. Jul 30, 2023 at 7:07 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I just take some corrosion X HD with the spray straw, remove all the rocker plugs and do a 360 in each hole. Then I replace the plugs and never mess with it again.
    Torspd likes this.
  9. Jul 31, 2023 at 6:47 AM
    SR-71A
    Zack
    Southern Maine
    Interesting, never heard of Corrosion X
    I also do the weep holes every year. Im hoping that has helped ward off the worst of it. I like the idea of using a zip tie to clear out the holes too. I need to do that to both the rockers and the door drains. Both have gotten filled up with mud and old fluid film over time.
    The 360 degree spray wand that comes with the 6-pack of FF aerosol does a real good job of misting the contents. And it should fit easily into those little plugs. That will probably be the way I go
  10. Jul 31, 2023 at 6:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Various types of CorrosionX. Find the type best suited for your needs. In my case, I have used the CorrosionX HD for the frame. It is thicker and tackier than the regular.
  11. Jul 31, 2023 at 8:06 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Best thing about the regular corrosion X is it smells like coffee (lol at least to me). The regular corrosion X in the red can is pretty thin and leaves a very thin film. Probably is more ideal to do inside the rockers.
    The HD stuff goes on pretty heavy and will leave a greasy layer on anything you apply it to, and it will not come off something like the frame unless you physically wipe it off.
    SR-71A[OP], spitdog and Torspd like this.
  12. Jul 31, 2023 at 9:32 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I use Fluid Film on my two Tacomas, and for the rocker panels I use the long flexible straw that FF sells. It's nicely made, replacing the standard nozzle with one to which is attached a long tube with a tiny 360º brass spray nozzle on its end.
    I got a three-pack of FF rattlecans plus the extension sprayer from the Big A.
    Torspd likes this.
  13. Jul 31, 2023 at 10:47 AM
    SR-71A
    Zack
    Southern Maine
    Yup, thats the 360 nozzle I was talking about. Ive had very good luck with it. Cant see any reason why it wont work for the rockers too as long as the little plugs allow enough access to bend the hose
  14. Jul 31, 2023 at 1:21 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    My only gripe with fluid film in the rockers, and likely won’t affect you cause you are in Maine but even in Maryland, when it gets hot out or vehicle gets parked in the sun, that sheep ballsack smell gets cranking and you can smell it in the cab. Eventually it gets better but still.
    E3g, drewnali, wi_taco and 1 other person like this.
  15. Jul 31, 2023 at 1:25 PM
    spitdog
    Yep, ^^ if you put the ac on recirculate it does help.
    E3g likes this.
  16. Jul 31, 2023 at 4:12 PM
    winkel
    Corydon, IN
    Years ago, one of my dad's work trucks had a diesel tank in the back that he used to fill his back hoes and dozers, out in the field. Years later, he got out of the business and sold off the equipment. A friend of the family bought that truck and I painted it for him. It was pretty beat up and had a lot of little rust spots on it. Where the diesel had spilled and puddled over the years, it had a film of lightly greasy dirt. When we took that tank out and cleaned it up, the paint under all that diesel looked like new.
    Moral of the story?? People will criticize the use of a light oil, but even that is better than nothing. The nice thing about the WD-40 knock off stuff from DG, is that it's really easy to apply while you roll around under your truck on a creeper. It sprays a bit farther than Fluid Film too. I'm not saying not to use FF, but just use something!
    4x4Taco2012 and SR-71A[OP] like this.
  17. Aug 1, 2023 at 12:48 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I use Woolwax because they had a black dyed version first, and because it's thicker than Fluid Film. I have their spray gun to use with my compressor and pair it with the 360° nozzle extension which works great. I've sprayed anywhere and everywhere I can reach inside and outside of the frame and rockers, apply it once each year but it's like 3 layers deep now and almost like a second layer of paint at this point. Has it's own smell but it isn't the "sheeps ballsack" and won't run when it gets hot outside.
    https://www.woolwaxusa.com/32-Flexi...r-Woolwax®-PRO-gun-with-360°-nozzle_p_53.html
  18. Aug 1, 2023 at 12:53 PM
    SR-71A
    Zack
    Southern Maine
    If you can get the full spray gun 360 nozzle in there I guess I wont have any issues with the one meant for aerosol cans. That's like 1/4 the diameter of the spray gun one
    wi_taco[QUOTED] likes this.
  19. Aug 2, 2023 at 8:15 AM
    spitdog
    I did my rockers today after I greased the drive train. Since I had a full can of FF I just used that and the 360 straw. I also cut a piece of bailing wire the length of the straw and taped it to the straw to give in more rigid strength so you can push it in the length of the straw. You only need to pull 3 or 4 plugs per side with just your fingers. The holes are probably 5/8.
  20. Aug 2, 2023 at 8:37 AM
    SR-71A
    Zack
    Southern Maine
    Bailing wire - awesome idea :thumbsup:
