Best way to Fluid Film rockers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SR-71A, Jul 30, 2023.
  1. Aug 2, 2023 at 8:40 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    A wire coat hanger would probably even be better. I didn’t have one. A coat hanger will spring right back to being straight.
  2. Aug 7, 2023 at 10:56 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The 3M Cavity Wax 08852 spray can with 08851 wand kit work great for this…. Odor is low/disappears.
    Torspd and SR-71A[OP] like this.
  3. Aug 14, 2023 at 11:23 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Can you tell me what you did with bailing wire - is it just one strain of wire ? Did you tape it to the straw or wrap it around - any pictures and or links ? Thanks for any reply.
  4. Aug 14, 2023 at 11:45 AM
    spitdog
    I just cut a length as long as the straw and taped it to the straw. It keeps the straw ridged so when you push it in those drain holes it doesn’t curl up inside the rocker. It’s just one strain of wire.
  5. Aug 14, 2023 at 1:28 PM
    george3
    New Jersey
    Thanks for the reply and information - did you use masking tape or electrical tape ? I had the same problem with it bending last time and I'm ready to do it again.
  6. Sep 5, 2023 at 6:52 PM
    george3
    New Jersey
    I bought the Woolwax Pro Undercoating Gun - I had the Standard Gun - I would recommend the Pro Gun - the Extension Wands do not bend and kink like the Standard Gun. I had to prime the Standard Gun before I could use the Wand - I didn't have to prime the Pro gun. If you go on their Web Sight you can get a discount and free shipping so the price was better then the big A. I use linseed oil - it's easy to use, not expensive and dries so dirt doesn't stick to it like a lot of other products.
  7. Sep 8, 2023 at 3:51 AM
    blairrad
    blairrad Yoter
    Missouri
    ….please go on.
