Best way to get 2.5 inches on Dbl Cab 2wd Tacoma??
Discussion in 'Suspension' started by Gabe911, Feb 4, 2012.
  1. Feb 4, 2012 at 9:55 AM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    I've read a bunch of different threads and have come up with a couple of choices. Hope those who have a 2.5" lift can chime in. I already have the TSB done to the rear and now want to do the front as well as add something to rear to make level or slight factory rake. I believe with all these choices I can opt for 3" down the rode but for now I want to see how the 2"-2.5" rides...I appreciate any and all comments
    (a) Toytec/Bilstien adjustable coilover 2.25 or 3" of lift
    [​IMG]http://www.toyteclifts.com/components/com_virtuemart/shop_image/product/Toytec_height_ad_4dfa8df35dcc5.jpg
    (b) 5100's set 0 w/ Eibachs and DS 1/2" top plate spacer / PS 1/4" spacer
    (c) 5100 set .85 w/ Eibachs with (1) 1/4" top plate spaer
    (d) complete OME kit with either 884 coils or 885 coils
    (e) any other recommendation
  2. Feb 4, 2012 at 9:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Best for the money is the OME lift. If you want to save some cash, the 5100/Eibach combo is a good choice. The OME will ride softer on the street than the 5100. the 885 springs will give about 3" lift, while the 884's seem to give 2", but some have gotten almost 3 for some reason.
  3. Feb 4, 2012 at 11:54 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    thank you...appreciate the insight....I will be making my choice here soon...just need the extra shove...so far it looks like OME kit w/ 884 coils...with a 1.5 aal in the rear I don't think the tsb will be enough rake...thanks again
  4. Feb 6, 2012 at 5:32 PM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    So, do you think 884's w/tsb no aal, will sit level ? Ive been searching all over this forum and getting conflicting info. Right now my rearend is 2 " higher than my front. I have the tsb rear leafs. I want it level. 884's or 885's? Thanks and good luck
  5. Feb 6, 2012 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think you might be better off with the Eibach 1.6" lift springs
  6. Feb 6, 2012 at 7:13 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    I agree Eibachs are probably what I am going with...RLDtaco is running this set up and look awesome..look at his gallery...hope it helps
  7. Feb 6, 2012 at 7:20 PM
    txduckhunter
    txduckhunter Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    Spacers or body lift FTW!!!!
    Haha had too!
