best way to get 3''-4'' lift?
Discussion in 'Suspension' started by kam, Nov 18, 2009.
  1. Nov 18, 2009 at 7:43 PM
    kam
    kam [OP] Well-Known Member
    Fullerton
    04 1st Gen. Extended Cab
    ok so i want to get a 3 inch to 4'' lift on my taco. what would be the best
    way to do it? i don't want to get something thats going to break on me
    within months. i will be doing minor off roading, nothing crazy. so its
    mainly for looks but i still want something thats decent for the dirt. i
    also want my ride to still be smooth. all these different type of lifts are
    confusing the crap out of me lol. but i'm kinda sorta getting the hang of it.
    now will it be cheaper if i buy everything seperate or should i just buy a
    lift kit with everything already there and have someone install it?
    i do plan on paying for the install because i will just end up messing
    something up trying to do it myself.
  2. Nov 19, 2009 at 1:08 PM
    kam
    Fullerton
    lets say i get the 5100 in the front and set them to 2.5 is there any way to add on to that lift?
  3. Nov 19, 2009 at 1:10 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Mostly everyone agrees, DO NOT STACK LIFTS.
  4. Nov 19, 2009 at 1:10 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Get some OME coils on top of that
  5. Nov 19, 2009 at 1:11 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You could add a body lift. You can't stack suspension lifts though.
  6. Nov 19, 2009 at 1:12 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    do you have a 4x4? if no get spindles, 4", if yes its 3" or 6".
    choices of 5100, eibach, toytec, king, ome, icon..
  7. Nov 19, 2009 at 2:00 PM
    kam
    Fullerton
    i don't have a 4x4 and i'm trying to stay away form body lifts. now what exactly are coils? lol
    guessing its the ''spring''?
  8. Nov 19, 2009 at 2:35 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    Definitely agree. Since you want that soft ride (which 5100s will not provide when used to lift) get the spindles which allow you to lift without altering your ride.
  9. Nov 19, 2009 at 2:45 PM
    hockeypoor
    hockeypoor Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
  10. Nov 19, 2009 at 2:46 PM
    danbow
    danbow Well, known member
    Daniel
    Wichita Falls, TX
    09 DCSB TRD OR 4x4
    Scratches and Dents
    Best way to get 3 to 4 inch lift for free right here:
    Find a 3 to 4 inch curb and drive up on top of it and your truck is instantly 3 to 4 inches higher!!
    Sorry, I know that was dumb (but not as dumb as stacking suspension lifts!)
  11. Nov 19, 2009 at 3:28 PM
    08pretaco
    Oliver
    az
    ya coils are springs. ome and eibach make springs, dont know who else.
    best route to go would just be buying a set of coilovers or again the spindle is probably the absolute best way to achieve lift keeping stock suspension geometry
  12. Nov 19, 2009 at 4:29 PM
    kam
    Fullerton
    now with spindles do i have to get the 5100? or do they usually just use the stock shocks and coils? and when you say 1.5 in wider per side is the way the tires kinda flare out right?
  13. Nov 19, 2009 at 5:54 PM
    08pretaco
    Oliver
    az
    this is where im not sure, im pretty damn sure you could use stock shocks and springs, because its a spindle "drop" its just dropping where the hub assembly sits and thats where your getting your lift from.
    the plus side to getting say camburg coilovers with the upper control arm is that you will get a little bit more articulation than the 4" you originally have.
    yes it does give you wider stance but it depends on the backspacing of your wheels and what size tires you decide to run.
    oh and one more thing from what people say who run spindles here get 4.5 backspacing wheels otherwise you may encounter some rubbing
  14. Nov 19, 2009 at 8:18 PM
    Kenny650
    Kenny650 Well-Known Member
    Lift spindles alter your ride no matter what. I should no because I have them and my shop couldn't get to factory specs.
  15. Nov 19, 2009 at 8:47 PM
    08pretaco
    Oliver
    az
    so can you use stock suspension up front with them or no?
  16. Nov 19, 2009 at 9:40 PM
    kam
    Fullerton
    well i'm looking at the 5100's with 10mm enhance kit. hows that sound? you all say not to stack lifts. is this stacking lifts?
  17. Nov 19, 2009 at 9:47 PM
    kam
    Fullerton
    oh and how many leaf's do you think i should get? 3? 4? 5? whats the difference between 3 and 5? thanks.. really appreciate everyones help.
  18. Nov 20, 2009 at 12:53 AM
    Kenny650
    Yes.
  19. Nov 20, 2009 at 6:45 AM
    08pretaco
    Oliver
    az
    whats a enhance kit?
    only putting a 1/2" spacer on tops not really stacking lifts so that will be fine. lots of people use the 1/2" spacers with their OME lifts to get the full 3".
    what are you looking for in the back, to level it, have some front rake have back rack? also what height are you gonna run with the 5100's and the top plate? if your gonna be close to 3" and want back rack keep it stock or maybe someone has like a 1" add a leaf , level rake probably just a 1.5" add a leaf, and front rake you might need to go 3" in the back.
  20. Nov 20, 2009 at 9:19 AM
    kam
    Fullerton
    yeah i'm looking at the 10mm enhance kit from ome. its cheap and adds little less then 1.5'' if i can remember correctly. i'm looking at a 1.5'' 3 leaf aal for the back to make it even. i plan on running the 5100 up front at 2.5 so i'll have about 3'' maybe a little more. now whats the difference between a 3 leaf and a 5 leaf aal? would it be better if i go with the 5 leaf? or is the 3 leaf enough for dirtbikes? lol
