best way to get a lift
Discussion in 'Suspension' started by dunkhi, Jan 18, 2009.
  1. Jan 18, 2009 at 4:53 PM
    dunkhi
    dunkhi [OP] CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    i have the adjustable 5100's set to 1.75 right now.
    i want to be able to get about a 3 or 4 inch lift on my truck.
    can anyone tell me the easiest way to do this?
  2. Jan 18, 2009 at 4:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    new set of coils for the front, and aal's for the rear.
  3. Jan 18, 2009 at 5:03 PM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    Toytec sells a coilover kit for your shocks that would give you up to 3.5" of lift and a AAL in the back would do you just fine. if you plan on going higher I would go with some new UCA's as well.
    Gary
  4. Jan 18, 2009 at 5:48 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    do u think u can give me a link to those.
    would the shocks be set at 2.5? and then coil overs add another lift?
  5. Jan 18, 2009 at 5:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no.......you will not need to preload the coils. set the shocks back to the stock setting when you use the new coils..............the coils will give the lift.
  6. Jan 18, 2009 at 5:53 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
  7. Jan 18, 2009 at 5:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  8. Jan 18, 2009 at 5:59 PM
    Alaskaflyer
    Cape Cod, MA
    You could go either way, they will both achieve the amount of lift you are looking for, one has the option of being adjustable. I am going with the 885 coils myself, got them sitting in the garage right now, just need to get my TC UCA's and I'll be ready to go!
    Gary
  9. Jan 18, 2009 at 6:03 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    heres the thing.
    i could adjust my shocks to 2.5 and get it aligned for like 100- dollars.
    or i could get the 2nd kit and get .5 inches more for 300 dollars.
    what would you guys suggest?
  10. Jan 18, 2009 at 6:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yep. Just have your shocks moved up to the top setting
  11. Jan 18, 2009 at 6:10 PM
    Alaskaflyer
    Cape Cod, MA
    If it were me it would depend on how your truck rode with the shocks adjusted all the way up. If it rides to your liking and you can fit the size tires you want just stick with your current set up. A lot of people run the 5100's and are very happy.
  12. Jan 18, 2009 at 6:24 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    if i went to a shop and had them extend the shocks to the max what else what i need besides alignment
  13. Jan 18, 2009 at 6:26 PM
    Alaskaflyer
    Cape Cod, MA
    I'm pretty sure that would be it.
  14. Jan 18, 2009 at 6:27 PM
    Alaskaflyer
    Cape Cod, MA
    How do you like your Magnaflow exhaust? I just got one but haven't installed it yet.
  15. Jan 18, 2009 at 6:31 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    what kind do u have?
    the one im using is a signature ivan stewart series.
    im sure theres no difference then the normal cat back.
    but i love it.
    it sounds great and fits the trucks personality/style.
    not extremely low. but has a great classy tone and still makes people turn heads
  16. Jan 18, 2009 at 6:34 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    oh ya.
    and do u think 2.5 shocks. and some spacers would work?
    or do the shocks have to be all the way down
  17. Jan 18, 2009 at 6:40 PM
    Alaskaflyer
    Cape Cod, MA
    I just got the cat back, if it's like yours then it sounds like what I was looking for. I would avoid a spacer. if you want to go higher than what your shocks will give you, you will have to get some springs up there. The 885 kit from Toytec is an affordable way to go, spacers give an extremely harsh ride among other issues. It's an expensive addiction but with the model truck you have I wouldn't skimp.
  18. Jan 19, 2009 at 12:56 AM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
  19. Jan 19, 2009 at 5:38 AM
    Alaskaflyer
    Cape Cod, MA
    I believe so. You can call or email doug at Toytec, they should answer all your questions. Also talk to Neubs here on TW he can get you a discount.
    Gary
  20. Jan 19, 2009 at 5:41 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
