Best way to get off sticker goo?
Discussion in 'Detailing' started by mcleod90, Apr 20, 2011.
  1. Apr 20, 2011 at 7:46 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    I'M HERE FOR TEH BITCHEZZ
  2. Apr 20, 2011 at 7:50 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Wouldnt rubbing alcohol fawk your paint? I think I read a while back that wd40 works well too?
  3. Apr 20, 2011 at 7:55 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    No, rubbing alcohol does wonders. Only bad thing is it strips all the wax so you will have to re-wax your vehicle. I used rubbing alcohol to remove over spray from plasti dip and excess gunk from when I removed my pinstripes :D
    Its also good for bugs, water spots, road grime, etc.
  4. Apr 20, 2011 at 8:00 PM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    thanks for the responses. theres still a haze on the truck. so i guess ill just have tompaint the badges then reapply them over the hazy spots. it also looks like i have to pm sockmonkey for some new decals to go over the haze.
    LESSON OF THE DAY! USE GOO GONE! AND WHEN YOU HAVE SOMETHING IMPORTANT TO SAY, CAPS IS THE ONLY WAY TO GOOOOOOOOOOOO!!!!!
  5. Apr 20, 2011 at 8:03 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Now you have to get the "grinder" out ... 80 grit should do it ... :eek: ... j/k
    Seriously ... use a heat gun (not too close) or a hair dryer in direct sun and rub (kinda roll the adhesive) off gently with a rubber glove. You can rub it off your your fingers, but it will make them a bit raw.
    The more direct sun light and higher the temp, the easier it is to get it off.
  6. Apr 20, 2011 at 8:04 PM
    malander
    max
    01 limited trd 4x4
    I thought goo gone made it hazy?
  7. Apr 20, 2011 at 8:07 PM
    Texas Taco 11
    Texas Taco 11 Parrothead
    Jax
    Houston, Tx
    '11 Dbl. TRD OffRoad PreRunner
    one week old! give it time...
    only 2 questions.
    Goo gone work for badges as well or just stickers? (like TRD)
    I read other descriptions of badge removal but am very wary. I can't afford a new paint job. Is it safe?
  8. Apr 20, 2011 at 8:30 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    its just cloudy. i dont know what it is because the only hazey part is right above the decals and emblems.
    ill try and get pics tomorrow
  9. Apr 20, 2011 at 8:36 PM
    beckleyota
    beckleyota Well-Known Member
    wv
    o7 taco
    vent visors,tint,kenwood headunit, trex eyelids,kenwood componants,5100's,1 aal,cabellas seatcovers,painted stereo suround
    the eraser wheel is the way to go i use one all the time at work just take your time with it cuz just like a buffer you can burn your paint but is the fastest way to take off double sided tape, stickers, decals, etc
  10. Apr 21, 2011 at 3:20 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Goo Gone is good for any kind of adhesive, badges, stickers, etc. I used it when I removed my badges(to get what was left after I peeled what was renaming of the emblem tape) and I used it on the adhesive from my TRD stickers. I've used Goo Gone on all my vehicles for this type of stuff it's always worked.
  11. Apr 21, 2011 at 5:19 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    I TRIED.....IT"S ALL I CAN DO OP
