Best way to get out of snow?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RodH, Mar 22, 2021.
  1. Mar 23, 2021 at 12:45 PM
    #41
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Glad someone said it! I was thinking "well I hope nobody starts airing down before heading out in a couple inches of powder on the road."
    MQQSE, tacoman45 and 5nahalf[QUOTED] like this.
  2. Mar 23, 2021 at 1:00 PM
    #42
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Sounds like you have a pretty good idea of what to do. Shovel, traction boards, snatch strap are all good things to keep in your bed. Airing down always helps increase traction in my book. Except for maybe ice.
    This isn't directed to you OP, but I think alot of people mix up the concepts of friction & traction - friction is what you want in icy conditions and is a direct function of the weight of your vehicle distributed over the contact area of your tires. Coefficient of friction is literally the tangent of (normal force (weight) / lateral slip force on surface). Higher weight means higher lateral slip force in most cases. This is the reason why you see ice rally cars w/ pizza cutter tires.
    Traction is a function of the aggregate interlock strength of your material beneath your tires. Materials with a low aggregate interlock force are easily displaced & moved (think sand as opposed to compacted gravel). If you take the weight of your truck and distribute it over a larger bearing area (IE - airing down your tires), you lower the amount of force you apply to the material and displace/crush less of the material when trying to move your tires. This allows you transmit force from your tires into the ground more efficiently and move your truck without spinning your wheels.
  3. Mar 23, 2021 at 2:37 PM
    #43
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Lots of people do mix this up. It's why when I buy winter tires I buy ones that are good for ice not snow. Where I live the roads are ice-covered most of the year. It's why I use narrow Blizzaks and not wide Duratracs. Some tires are good for winter ice. Some are good for deep snow. Rarely is that the same tire.
    More to your point....skates are good on ice. Snowshoes are good in snow.
  4. Mar 23, 2021 at 11:20 PM
    #44
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    All good posts ... a little bit Bill Nye the Science Guy, but valuable explanations if folks take the time to read, understand, and digest.
    So, if you skipped here 'cuz it's a short post, go back and read the long stuff. Good information is a valuable commodity.
    Respect :oldglory:
    Rob
  5. Mar 23, 2021 at 11:26 PM
    #45
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not all snow is the same so there really isn't one answer.
    I'm sure the fact about airing down in the snow not helping was not considering deep snow and off roading. Under normal conditions on the road, it's not a great idea. In your case, absolutely.
    I have a shovel attached in my bed in the winter time for high centering on snow banks or snow that's just plain too deep. It's a feed/grain shovel which is great for moving a lot of snow at once.
  6. Mar 24, 2021 at 1:33 AM
    #46
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :cookiemonster:
    Real Beadlocks even possible? :notsure:
    :hattip: Rich
    Matic[QUOTED] likes this.
  7. Mar 24, 2021 at 4:28 AM
    #47
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Lots of good advice, some ? Shoveling out of snow only thing I can add is make sure you're in good health. It's easy to get exhausted with cold and frustration.
    MQQSE likes this.
  8. Mar 24, 2021 at 5:03 AM
    #48
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Although I have never aired down to 2 psi(to afraid to try), I have aired down to 15-19 psi and it has helped me many a time in many conditions including snow. But have not done anything in this taco yet. Up in Breck at 11,500 ft, I was pulling two suburbanites in suburban and tahoe, out of the snow with my F350. Airing down helped me yank one out. The other was so stuck that I had to put chains on to get enough traction to pull them out. It almost always seems that it is a competition in the mountains on who can get to a stranded truck to help them out. Everyone wants to try out their rig. lol.
    In your case, I would get a strong harness for the wife along with spikes for the shoes, nice tow strap and have her help pull you out.
    44-16 Taco, ndoldman59 and MQQSE like this.
  9. Mar 24, 2021 at 5:24 AM
    #49
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    “Honey I need you to ass-up the back of the truck”
    - yeah, no recovery at all from that! :rofl:
  10. Mar 24, 2021 at 5:30 AM
    #50
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Are you saying you aired down to 1-2 lbs or that you let out an additional 1-2 pounds? If you aired down to 1-2 pounds you are lucky you didn't pop all 4 beads.
  11. Mar 24, 2021 at 5:39 AM
    #51
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    And to that point, always turn trac off before you hit the deep snow. Depending on conditions, that extra wheel speed without traction control cutting power can make the difference between pushing through or not.
  12. Mar 24, 2021 at 5:40 AM
    #52
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    That last paragraph :ohsnap: & video please :pray:
    :facepalm: :itllbuffout: ? Don't think so. :eek:
    CJH9980 and davidstacoma[QUOTED] like this.
  13. Mar 24, 2021 at 5:43 AM
    #53
    SR-71A
    Zack
    Southern Maine
    Damn dude thats a genius idea. So simple. Also I love the fact that yours is cracked in the same exact place an mine :rofl:
    RedWings44[QUOTED] likes this.
  14. Mar 24, 2021 at 6:55 AM
    #54
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    FWIW, I've seen some amazing YouTube videos of folks using Crawl Control to extricate themselves from some serious "stucks" but usually in sand. I have been wanting to try this myself, but we haven't gotten any noticeable snow since we got our truck in December. Of course, if you don't have Crawl Control then you couldn't try this either. I always carry a snow shovel in winter too.
    DirtyPixelADV likes this.
  15. Mar 24, 2021 at 7:13 AM
    #55
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    This method seems to work and is a cheap DIY. Works pretty well for sand and mud as well.
  16. Mar 24, 2021 at 7:48 AM
    #56
    RedWings44
    Michigan
    Lol, thanks. Not sure if you can tell or not, but I have a hose clamp on it too as a "just in case." But it still works! Years of cold and just being loose in the back of my last truck lol
    MQQSE likes this.
  17. Mar 24, 2021 at 7:52 AM
    #57
    tacoman45
    Orygun
    It's definitely good "big picture" info to have for all situations if you take the time to digest the concepts behind it. This is the type of useful science that's beaten into your head in engineering school.
    For the record, Bill Nye the Science guy is an engineer, not a scientist. Scientists think of shit while engineers do shit ;)
    doublethebass and MQQSE[QUOTED] like this.
  18. Mar 24, 2021 at 7:53 AM
    #58
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Tire chains are cool
    SR-71A likes this.
  19. Mar 24, 2021 at 7:54 AM
    #59
    tacoman45
    Orygun
    I've actually done this with some small logs and some rachetstraps. Worked like a charm.
  20. Mar 24, 2021 at 7:59 AM
    #60
    SR-71A
    Zack
    Southern Maine
    Im up to 2 on mine :D
