Best way to get rid of AC Stink?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Creel, Apr 15, 2010.
  1. Apr 15, 2010 at 6:01 PM
    Creel
    Creel [OP] Well-Known Member
    Georgia
    08 SWB DC PreRunner OR
    Well its that time of the year again and things are starting to heat up. I've had to use my AC a few times now and each time I start it .. I get the wonderful smell of socks and cheese :(
    It does go away eventually or I get used to it. What is the best way to remedy the smell?
  2. Apr 15, 2010 at 6:02 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    have you replaced your cabin air filter?
  3. Apr 15, 2010 at 6:05 PM
    Creel
    Georgia
    Yes I just did that recently just in time for pollen season.
  4. Apr 15, 2010 at 6:09 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Replace your cabin air filter. Then if that doesn't work. Theres some stuff you can buy at a detail supply place that you spray in the inlet and let it circulate. Its suppose to kill any mold spores that might have formed on the evaporator. You can also spray a can of lysol in there while the AC system is on and the blower motor is on high.
  5. Apr 15, 2010 at 6:13 PM
    Mainehunter
    Mainehunter Member
    Jim
    FL panhandle
    09 DC 4x4 TRD offroad
    I've also heard that before shutting off truck once in a while you should run full heat for a bit to dry the condensation out before it has a chance to cause mold, never had need to use it though so can't verify it works.
  6. Apr 15, 2010 at 8:20 PM
    Creel
    Georgia
    May be a dumb question but the air intake under the hood? :confused:
  7. Apr 15, 2010 at 8:27 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Get that spray for the moisture outlet or just run your a/c year long like I do in Cali
  8. Apr 15, 2010 at 9:42 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    You can spray the duct cleaner from the inside or outside, just make sure if you're doing it from the outside you have the a/c set to fresh air not recirculate. Also remove your cabin filter before you do the cleaner or it will not work and the filter will catch everything before it gets to the evaporator.
    Also at the dealership I work at (Kia) we have an a/c deodorizer kit that comes with this foam cleaner that you spray in through the evaporator drain tube and it fills the evaporator box with foam that cleans the evaporator and then turns to liquid and drains out of the system to help with the nasty gym sock smell. I'm not sure :confused: but I bet you could find something similar to this at your local parts store. It works great!!:D
  9. Apr 15, 2010 at 10:26 PM
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    hey guys how do you change your cabin filter out? Is there a how to thread for this?
  10. Apr 15, 2010 at 10:29 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Im sure there is, just pull your glove box out, then there is a plastic door straight ahead, just open it and pull it out.
  11. Apr 15, 2010 at 10:43 PM
    DheadTaco
    Never messed with the glove box before. If i go and check it out would I figure out how to take it off?
  12. Apr 15, 2010 at 11:01 PM
    Tactical Me
    Tactical Me Member
    Kevin
    Severn, Md
    2010 SR5 Access Cab
    Allpro Offroad Bumper, TSB Leaf Springs, Toytec Ultimate Kit, Total Chaos UCA, Weathertech Digi-tech
    I use a fabric softener sheet to mask the air conditioner smell. It removes dust and adds a nice Bounce scent to the air. Try adding one to the cabin intake or just behind your floor vent. Be sure to change it out every few weeks.
  13. Apr 16, 2010 at 2:42 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Just get some decent smelling Lysol and spray it in the cowl.
  14. Apr 23, 2010 at 7:53 AM
    Jreays
    Jreays Member
    Jeremy
    Ohio
    09 4x4 Sport Double
    My last car... Pontiac G6 would run the fan 30min after the car was turned off. It would run for 5 min and then turn off for 30 and then turn back for 5. It was something the dealer had to turn on. It fixed the problem. Can our trucks do something like that?
  15. Apr 23, 2010 at 8:06 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I found a way that works pretty good here in the desert climate. If you've been driving around with the A/C on, turn it off and run the fresh air only for the last few minutes before you park. That dries most of the moisture out. Then when you restart, just turn it back on. It cuts the smell at least in half.
  16. Apr 23, 2010 at 11:24 AM
    GT150
    GT150 Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    Are these trucks suppose to drip condensation out of the system like other vehicles? Because my truck is new and the air smells, and I haven,t seen any water draining.
  17. Apr 23, 2010 at 11:29 AM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    If you still have your owner's manual, it tells you how to take out the glovebox.
  18. Apr 23, 2010 at 11:32 AM
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    My truck is brand spankin new and I get that smell every so often (we here ix the AZ haven been running the AC for a while now) and I just roll my windows down a bit to let the stink out.
    hip
  19. Apr 23, 2010 at 11:56 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The AC condenser coils are before the heater core so turning the heat on doesn't help. What does help is shutting off the AC for the last 5 minutes or so, and running the blower fan, this dries out the coils. Stopping the mold and mildue that causes it to stink, in theory......
  20. Apr 23, 2010 at 2:23 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks, sounds like the way to go.
