Best way to get to fuel filter??
Discussion in '4 Cylinder' started by wolfgang123, Dec 16, 2010.
  1. Dec 16, 2010 at 6:16 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So i went to change my fuel filter today and noticed that its DIRECTLY under the intake manifold!! i read about taking the wheel off and getting to it that way but even then i couldnt see how to truelly get at it? am i going to have to remove the manifold to change it?
  2. Dec 16, 2010 at 7:14 PM
    loeborg
    loeborg Active Member
    Greenwich, CT
    1998 Tacoma SR5
    I'd like to know the answer as well.
  3. Dec 16, 2010 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    When I did mine, I removed the intake manifold. But....I also installed a supercharger at the same time :eek: You can get to it from the driver side wheel well, but its tight. The only other option is to remove the intake manifold.
  4. Dec 16, 2010 at 8:41 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    uhh i thought about intake manafold...anything special with that or can i just remove and re-install?
  5. Dec 16, 2010 at 9:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nothin special. Its a 2 peice manifold, but its pretty straight forward.
  6. Dec 17, 2010 at 5:57 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok i guess i will take the manifold off then
  7. Dec 17, 2010 at 5:59 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  8. Dec 17, 2010 at 6:51 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I looked at mine too and thought the samething. I wonder if a good set of crowsfoot will work?
  9. Dec 17, 2010 at 10:37 AM
    mdub
    mdub Active Member
    Missouri
    01 Tacoma Ext Cab
    3" Body Lift 15" Wheels, Over sized Tires
    I used a set of crowsfoot to make sure I had a good hold on the nuts. Last thing I wanted to do was jack something up in such a small space. I have a 3" body lift on the truck (it came with with or it wouldn't have it) and that made my swap a lot easier, just plan on busting some knuckles, cursing a little, have a beer in the middle to calm down for the installation....
  10. Dec 18, 2010 at 1:16 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    im just going to take the manifold off :(
  11. Jan 17, 2011 at 4:55 PM
    Axkicker03
    Axkicker03 New Member
    Kevin
    NC
    97 Tacoma 2.7l 4x4
    Bilstien Shocks and Struts
    Just did mine. It is my first toyota truck and I have some good sized paws. I went through the wheel well. Next time I'll have a have a beer or two and curse before I start. One or two midway through(curses and beers), and 2 more to celebrate[​IMG].
