Best Way To Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bama 14, Nov 21, 2012.
  1. Nov 21, 2012 at 7:20 PM
    Bama 14
    Bama 14 [OP] Member
    Cindy
    Mississippi
    2012 TRD OFFROAD
    I would like some input on the BEST way to do a 3inch lift. I know nothing about this sort of thing. I have a 2012 tacoma TRD Offroad. I want to do this Right. Read SO many different things that I am now confused.
    Also if you Lift does it void your Warranty???
  2. Nov 21, 2012 at 7:26 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Just DO NOT do a spacer lift if you want the best...
  3. Nov 21, 2012 at 7:36 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Best is relative, do you drive rocky trails? Blast through the desert? Describe what you want to do ( your driving style) and how much you can spend.
    To do a good 3 in lift, you should get replacement upper control arms (UCAs) and replace your leafs instead of using blocks.
    Just give us more info and we can help. It's like what is the best gun to get? Depends on what you want to shoot
  4. Nov 21, 2012 at 7:36 PM
    mutilatedjak
    WA
    +1
  5. Nov 21, 2012 at 7:37 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Budget and intended use?
  6. Nov 21, 2012 at 7:43 PM
    Bama 14
    Bama 14 [OP] Member
    Cindy
    Mississippi
    2012 TRD OFFROAD
    Actually I just want the lifted look. I hunt so I go off road but can do that with the way it is now. Just for looks.
  7. Nov 21, 2012 at 7:45 PM
    Bama 14
    Bama 14 [OP] Member
    Cindy
    Mississippi
    2012 TRD OFFROAD
    I was going to do the 5100's but I only have 3 leaf spring on rear. 2012 tacoma don't have the upgrade thing.
  8. Nov 21, 2012 at 7:47 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Do a Toytec or OME kit. "Cheaper" but good options. Avoid spacers.
  9. Nov 21, 2012 at 7:47 PM
    DSYLEXC
    DSYLEXC Well-Known Member
    Western Arizona, USA
    SOLD:2012 Tacoma TRD Sport DCLB 4x4
    No, not at all. Don't let the ticket writers at the dealership try and sell you that nonsense.
  10. Nov 21, 2012 at 7:48 PM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    Best way to lift is with your legs, not your back.
  11. Nov 21, 2012 at 7:54 PM
    SLACK3R
    SLACK3R Well-Known Member
    Tucson AZ
    2013 dc trd or
    5100 front/rear, OME 885's, diff/carrier drop, 13/10mm spacers, Wheelers 2" AAL, LED map and dome lenses Bed mat MORE TO COME
    Well I just got mine back today and I am very pleased I did a lot of research on this site and changed my mind a couple of times. When the guys say its a better then stock ride they are correct, I found the stock ride to be stiff and choppy now it is firm but when you blast over a speed bump "the big ones in the neighborhood" you feel the difference very plush feeling. here is what I did.
    FRONT:
    5100 billies at stock setting
    OME 885's
    Light racing UCA's
    wheelers spacers 13mm on left & 10mm on right
    diff drop
    REAR:
    Wheelers 2 inch AAL
    Carrier drop
    5100 billies
    I measured my clearance on all four corners but I will wait till my fuel is at the same spot before I remeasure and then after a few months I will measure to if it settles. you can see in the first my lift in the back:) next will be wheels and tires.
    here is a before and after.
  12. Nov 21, 2012 at 7:57 PM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Looks very nice. Little jealous.
  13. Nov 21, 2012 at 7:59 PM
    JonnyBb
    Arkansas
    decent set up, although the general consensus is that the diff drop does nothing for 2nd gens.
    Using a Wheeler's 3-leaf AAL is the only other change I'd make to this setup.
  14. Nov 21, 2012 at 8:00 PM
    Bama 14
    Bama 14 [OP] Member
    Cindy
    Mississippi
    2012 TRD OFFROAD
    That is just what I want. Thank You. Now can you tell me where to get all this from and how much? Do you have the 3 leaf spring in rear?
  15. Nov 21, 2012 at 8:00 PM
    SLACK3R
    Tucson AZ
    2013 dc trd or
    i only did the aal cuz later I'm going to the Dakars
  16. Nov 21, 2012 at 8:04 PM
    SLACK3R
    Tucson AZ
    2013 dc trd or
    I got it all from Dan at wheelers offroad it was all $1138.39 and a buddy that works at the Toyota dealer put it on and did the alignment for $350
    yes 3 leafs
  17. Nov 21, 2012 at 8:09 PM
    Bama 14
    Bama 14 [OP] Member
    Cindy
    Mississippi
    2012 TRD OFFROAD
    Great and thanks SO Much. Just what I need to know!
    Your Truck Looks Great!
  18. Nov 21, 2012 at 8:09 PM
    JonnyBb
    Arkansas
    ToyTec and Wheeler's for me. Guys at Wheelers were really cool to talk to. Can't tell you the exact cost...$1K plus/minus with UCAs and lift kit.
    I run the 3-leaf AAL on the stock 3-leaf pack with the overload intact. Rides really smooth. Never heard anyone say they didn't regret spending a little extra for it.
    Do yourself a favor and don't skimp on UCAs. In-spec alignment numbers aren't good enough. You need 2.5-3* of caster. A lifted Taco can handle as good as (if not better) than stock.
  19. Nov 21, 2012 at 8:11 PM
    Bama 14
    Bama 14 [OP] Member
    Cindy
    Mississippi
    2012 TRD OFFROAD
    What is Dakars?
  20. Nov 21, 2012 at 8:14 PM
    SLACK3R
    Tucson AZ
    2013 dc trd or
    Thanks for the positive feedback guys, I racked my mind tryn to find the right set up because there are so many options to go with and a little nerve racking for me to start with such a new truck.
    The dakars are Old Man Emus rear leaf springs a very good progressive leaf spring pack with good flex and weight/load bearing there about $500 shipped give or take.
