Best Way to Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJKlug1, Mar 30, 2021.
  1. Mar 30, 2021 at 6:37 PM
    AJKlug1
    AJKlug1 [OP] Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I want to lift my 2nd gen non TRD Taco 2-2.5 inches. I am looking at Bilstein 5100s for the front. Should I do the front 5100's and look into AAL's. Thanks in advance!
    Mattynokes likes this.
  2. Mar 30, 2021 at 6:38 PM
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Should I assume that you know that the rear shocks aren’t what give you lift?
  3. Mar 30, 2021 at 6:44 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Yes I am aware of that, I worded my question incorrectly and edited it. What is the best way to lift the rear of the truck?
  4. Mar 30, 2021 at 6:46 PM
    Mattynokes
    Madison, WI
    Oh ok. AAL or leaf pack. Waiting on my shocks to install mine currently and the wait is killing me. :annoyed:
  5. Mar 30, 2021 at 6:47 PM
    Mattynokes
    Madison, WI
    Best answer will be determined by what you do with your truck, how much weight you normally carry in it and how much lift do you want?
  6. Mar 30, 2021 at 6:48 PM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Best way is full leaf pack, then AAL, then I guess the cheap way of blocks...
  7. Mar 30, 2021 at 6:49 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Have any brand recommendations for either? Are there pros or cons to either? Im pretty new to all this lol.
  8. Mar 30, 2021 at 6:51 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Not much weight, a small boat and the occasional 4,000 pound trailer
    Mattynokes[QUOTED] likes this.
  9. Mar 30, 2021 at 6:53 PM
    Mattynokes
    Madison, WI
    How often?
  10. Mar 30, 2021 at 6:54 PM
    Mattynokes
    Madison, WI
    Never blocks!
  11. Mar 30, 2021 at 6:54 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Deaver>Dakar’s>anything else
  12. Mar 30, 2021 at 6:55 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Oh man like 2-3 times a camping season if that. Depends whos truck we use
  13. Mar 30, 2021 at 6:57 PM
    Mattynokes
    Madison, WI
    If you want to do things on the cheap then AAL. Leaf pack will be quite a bit more, but, buy once cry once.
  14. Mar 30, 2021 at 7:01 PM
    Mattynokes
    Madison, WI
    I’m sure aal would be just fine for you. It would give you about 1.5-2”
  15. Mar 30, 2021 at 7:03 PM
    Mattynokes
    Madison, WI
    I’d go deaver
  16. Mar 30, 2021 at 7:05 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    I woudl idealy like to run a 2 inch lift, so would I look for a 2 inch AAL or go higher? Does it make a difference that I have the toyota AAL recall that added another leaf to the rear to make a total of 4 leafs.
  17. Mar 30, 2021 at 7:06 PM
    Mattynokes
    Madison, WI
    That I don’t know, maybe someone else has info on. But, to get a full 2” on a normal set up you just leave the overload leaf in when installing the aal.
    gkomo likes this.
  18. Mar 30, 2021 at 7:07 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    You don't have the info on the recall you mean?
  19. Mar 30, 2021 at 7:09 PM
    Mattynokes
    Madison, WI
    Correct.
  20. Mar 30, 2021 at 7:09 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Ok, I'll look into it. Thanks for the help!
