Best way to measure lift height
Discussion in 'Suspension' started by Tacoluver, Nov 4, 2009.
  1. Nov 4, 2009 at 2:37 PM
    Tacoluver
    Tacoluver [OP] Well-Known Member
    Norcal
    TRD Off Road shortbed
    Volant cold air intake, RevTek 3" Lift, Snug Top Toneau cover, Kenwood Navi, Jamoshi grill
    What is the best way to measure lift height on our trucks? At which points do you measure?
  2. Nov 4, 2009 at 2:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    From the center of the hub to the bottom of the fender for suspension lift.
    From the ground to the bottom of the fender for tire and suspension total lift.
    From the ground to same point the lowest object object for over all ground clearance.
    Making sure you use the same spots for before and after measurements gives yo the best info.
    BizzyB726 and Parma like this.
  3. Nov 4, 2009 at 3:16 PM
    Tacoluver
    Norcal
    Got it thanks! I got 24" from hub to fender. Should've measured before doing the lift. Do you happen to know what the specs are on stock suspension w/ stock wheels?
  4. Nov 4, 2009 at 3:26 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Was it 24 inches on all four tires??
  5. Nov 4, 2009 at 4:00 PM
    Tacoluver
    Norcal
    I only measured the drivers side. Tomorrow I'm swapping out my RevTek spacer lift for Bilies and OME's.
  6. Nov 4, 2009 at 4:01 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    ::nods:: I got about 19-20 inches in front and about 22 in the rear pre lift...
  7. Oct 8, 2020 at 11:21 PM
    Cutnweld
    Cutnweld Member
    This is a bad way to measure. Your bodywork (fender) can be off by as much as 1”.
    Best bet is your axle, where the spring mounts, to the bottom of the frame.
  8. Oct 8, 2020 at 11:29 PM
    su.b.rat
    su.b.rat broken truck
    Eric at Archive Garage always recommends measuring like this for the rear, so consider this your starting point:
    taking a measurement to get your actual ride height, measure from the top of the axle tube up to the bottom of frame rails, stock is 8.25"​
    Cutnweld likes this.
  9. Nov 11, 2021 at 3:06 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  10. Nov 11, 2021 at 3:11 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    So, that's a body lift?
    OffroadToy[QUOTED] likes this.
  11. Nov 11, 2021 at 3:40 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Not sure if that tire will rub... but I probably will...
    :spy::jerkoff:
  12. Nov 11, 2021 at 3:43 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I prefer the method of measuring from the shock's top hat to the lower bolt. This measurement would be consistent time and time again.
  13. Nov 12, 2021 at 10:35 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    This is helpful for comparing one setup to another for yourself but it doesn't actually give you the amount of lift relative to what people talk about 99% of the time. 1" of lift at the coilover is roughly 2" of actual lift if measuring the hub center vs body. Same way that a 1" spacer will give you 2" of lift.
  14. Nov 12, 2021 at 10:36 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    With a tape measure.
    otis24 and fatfurious2 like this.
  15. Nov 12, 2021 at 10:39 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    That's 100% of my point. If you're measuring lift at all, it's typically to compare one set up to another. Beyond that, just use your eyes and determine what "lift" looks good. The only way my measurement wouldn't be an accurate comparison between trucks, is if one of the trucks is LT, or running a DB.
  16. Nov 12, 2021 at 10:44 AM
    clenkeit
    Colin
    Lakewood, CA
    It's just completely useless for most people when they're looking online at pics and buying products - 100% of which will reference "lift" as based on hub center vs body. Once you're concerned with only your truck, tweaking your setup, sure use that method. But if you want to compare to anyone and everyone else then you'll want to stick with the actual lift amount rather than the change in coilover length. I personally don't have any trouble measuring hub to fender, sure, there's a little variation from person to person, but it's pretty minor. And that 1" difference someone else mentioned is phooey. The only time one person's fender is gonna be 1" different from someone elses s if it's an aftermarket flare or the flares were cut.
    Thatbassguy and wi_taco like this.
  17. Nov 12, 2021 at 11:03 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I've seen people measure hub to center and get measurements that were 1/2 inch off because their eyecrometer wasn't calibrated and couldn't pick out the center of the hub.
    wi_taco, gudujarlson and Bertw192 like this.
  18. Nov 12, 2021 at 12:32 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve been off 1/2” when measuring in low light.
  19. Nov 12, 2021 at 3:28 PM
    clenkeit
    Colin
    Lakewood, CA
    Yup, it's definitely not an exact science. Personally, I find it's easiest to first measure your ground to hub center and record that measurement. Then, take all your other measurements from ground to fender and subtract the ground to hub measurement. Takes a little variance out of the measurements and means you can measure and remeasure faster.
    (Note that, depending on your tires and tire pressures you may have different ground to hub measurements front and rear.)
    wi_taco and Island Cruiser like this.
  20. Nov 16, 2021 at 10:12 AM
    OffroadToy
    I thought i had a 6" lift until i figured out the measuring tape i used came out of my tackle box. :facepalm:
