Best way to power a freezer and toaster in the truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Nov 19, 2021.
  1. Nov 19, 2021 at 3:35 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    OK no worries, just trying to see if I can help find a workaround/substitution.
    Let’s try this: How big are the sandwiches and how many do you have to carry at one time? If you were not cooking them from your truck, how would you cook them in a house using regular kitchen gear?
  2. Nov 19, 2021 at 3:37 PM
    tcjacado
    tcjacado Well-Known Member
    They make 12 volt coffee pots too, just about every appliance has a 12 volt cousin. ;)
  3. Nov 19, 2021 at 3:38 PM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Would literally just be one sandwich per day, so super tiny freezer would work just fine. I might just have to go with the dry ice idea and pick up dry ice every few days or so.
    Like an idiot, I didn't even think that I would need to keep the truck on to power the freezer.
    tcjacado likes this.
  4. Nov 19, 2021 at 3:42 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You could wired it up directly to your battery, but that won't last more than half a day if that with a cheap, inefficient freezer...
    If you had a dozen of spare car batteries, you could wire them up and have them in your bed to potentially have enough capacity to run your freezer and toaster without ever starting up the truck...
  5. Nov 19, 2021 at 3:43 PM
    JasonLee
    15 TRD OffRoad
    Another option is to rent a Honda generator or buy a Harbor Freight knockoff and run your freezer and toaster off that.
    tacotoe likes this.
  6. Nov 19, 2021 at 3:44 PM
    drewskie
    Drew
    Burbank, CA.
    Ha. I think at that point I would just starve for the day.
  7. Nov 19, 2021 at 3:48 PM
    wi_taco
    Adam
    SE Wisconsin
    Couple more questions to help narrow down a reasonable solution:
    Cooking directions for said sandwich? (From my previous comment)
    Budget for this whole project?
  8. Nov 19, 2021 at 3:52 PM
    drewskie
    Drew
    Burbank, CA.
    It literally just goes in a regular two slice toaster. So I wouldn't need an oven or anything else. And I was hoping to keep the budget at a bare minimum since it will only be for probably 2 months, and I literally never go camping so it would be a waste.
  9. Nov 19, 2021 at 3:52 PM
    drewskie
    Drew
    Burbank, CA.
    I mean, I guess an inverter generator would work, right?
  10. Nov 19, 2021 at 4:02 PM
    wi_taco
    Adam
    SE Wisconsin
    Ok here’s what I would do for the toaster:
    Buy a propane camp stove that uses Coleman 1lb propane bottles. You should be able to find these just about anywhere for pretty cheap. Then get something like this below for toasting:
    https://www.amazon.com/gp/aw/d/B007HRIYDY?ie=UTF8#aw-udpv3-customer-reviews_feature_div
    That setup would let you toast things without complication or cost of electric powered toasters. Propane stove plus that toaster thingy probably less than $100. Sell the stove when done and recoup probably half your costs or more. Or start camping more.
    Freezer conundrum I’m still pondering…
    drewskie[OP] likes this.
  11. Nov 19, 2021 at 4:06 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Health issues, sounds like it might be worth investing in a good fridge. You don't have to go full Domestic, but with black friday deals afoot there should be some good deal.
    drewskie[QUOTED][OP] and wi_taco like this.
  12. Nov 19, 2021 at 4:15 PM
    wi_taco
    Adam
    SE Wisconsin
    I agree with Sandman if you can afford it. Lots of good quality compressor driven fridges but don’t be fooled this route still costs some coin.
    I’d wager even the most cost effective dual battery setup and good deal on a fridge would run $500 or more.
    Amazon/Chinesium 12v “freezer” and a Jackery power pack maybe under $500 but higher possibility to shit the bed.
    Low tech option of a cooler and dry ice / regular ice might cost you $1 per day and be a hassle but probably most cost effective if only doing for a month. Simple and seems easiest to me.
    All this food talk made me hungry, I’ve got to get dinner now…good luck OP on your quest.
  13. Nov 19, 2021 at 4:17 PM
    drewskie
    Drew
    Burbank, CA.
    Thank you. It's not so much the money I'm worried about, just feel like it would be a waste of a fridge after I am done although I could probably sell it. I am definitely leaning towards the dry ice option, and that way won't have to worry about draining any batteries or catching fire or anything either. Although picking up the dry ice will be a pain in the ass.
    Sandman614 likes this.
  14. Nov 19, 2021 at 4:18 PM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    I keep a few of these in my truck at all times. You dont need to keep them cold and they heat themselves if you just add water. My favorite is the chili with a bag of Fritos.
    https://omeals.com
  15. Nov 19, 2021 at 4:22 PM
    #35
    drewskie
    Drew
    Burbank, CA.
    Actually might have to check that out. Although the page is in French.
  16. Nov 19, 2021 at 4:23 PM
    #36
    wi_taco
    Adam
    SE Wisconsin
    One more possibly dumb question: for the frozen ingredients does it have to stay fully 100% frozen like a caveman on ice all day long?
    If not, and assuming you have a home base with a fridge/freezer, do a cooler with regular ice. For camping I freeze water bottles (specifically Dasani for thicker walled plastic) and throw in the cooler as reusable ice. You can also buy those ice packs but that gets expensive for a large cooler.
    That method may result in your frozen ingredients getting a little thawed but definitely the cheapest and easiest of all choices.
  17. Nov 19, 2021 at 4:24 PM
    #37
    10YSON
    GREG
    TACOMA & 4RUNNER
    Thats weird it's in English for me? If you live near a Sportsmans Warehouse they usually have them in stock next to the mountain house food.
  18. Nov 19, 2021 at 4:25 PM
    #38
    drewskie
    Drew
    Burbank, CA.
    I was actually just going to post this, it's not meat or cheese or anything like that so even if it does get thawed out I think it will be okay. I was actually exploring this option at first, but figured a tiny freezer would just make it easier, but apparently not.
    wi_taco[QUOTED] likes this.
  19. Nov 19, 2021 at 4:37 PM
    #39
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    I am assuming you are talking about someone else going with you, but even if you aren't, good for you for taking this into consideration. Mental health issues are serious, as "ridiculous" as they may sound to others. I have dealt with people close to me who suffer similar things.
    Hope you have fun on the trip.
  20. Nov 19, 2021 at 7:03 PM
    #40
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    I'm really curious about what sandwich ingredient has to stay frozen. Like an ice cream or what?
