Best way to power a freezer and toaster in the truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Nov 19, 2021.
  1. Nov 19, 2021 at 7:04 PM
    #41
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    They mentioned earlier it’s medical related and don’t want to discuss specifics. Best to respect their privacy.
    tcjacado, drewskie[OP] and blu92in99 like this.
  2. Nov 19, 2021 at 7:07 PM
    #42
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    …my money is on vampire.
    drewskie[OP] and crazysccrmd like this.
  3. Nov 19, 2021 at 7:33 PM
    #43
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Yeah but he’s the one that posted so I think it’s fair to ask follow up questions. It’s hard to offer solutions without fully understand the problem. It’s not like he has to give to many specifics. Like is it medicine that has to remain below freezing or does he just loose his s*** if he doesn’t get his hot pocket?
  4. Nov 19, 2021 at 7:44 PM
    #44
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Not a hot pocket, but a waffle. Seriously. Part of an eating disorder....
  5. Nov 19, 2021 at 9:16 PM
    #45
    6 gearT444E
    Deep South
    Herculiner Hootus
    get a Honda generator and transfer pump from the gas tank, you’ll be set!
  6. Nov 19, 2021 at 9:39 PM
    #46
    OrangeCrash
    OrangeCrash Well-Known Member
    Kingman, Az
    What about bribing some local TW'ers to just swing by and toss you the prepared food item over the fence?
  7. Nov 20, 2021 at 12:30 PM
    #47
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    Rent a reefer truck?
  8. Nov 20, 2021 at 1:59 PM
    #48
    $yoda$
    Tom
    2007 Tacoma 4.0
    Well if you start out frozen each day I’m pretty sure dry ice in a good cooler would keep it that way for some time. Toaster is a pretty easy problem to solve I think. If you need to run a freezer for any length of time I think realistically your going to have to look into adding additional batteries and a way to charge them every day. I’m going on the idea you will need to run it 24/7.
    drewskie[QUOTED][OP] likes this.
  9. Nov 20, 2021 at 3:36 PM
    #49
    drewskie
    Drew
    Burbank, CA.
    I may be overthinking the whole thing, and can just use dry ice since it's a waffle I mean won't really go bad. I don't think the freezer would have to be on for more than 7 hours a day
  10. Nov 20, 2021 at 3:49 PM
    #50
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    How much sun will you be getting and is it in a safe area?
    For the frozen portion I would personally get a small dometic dual zone, a portable battery like a goal zero (or build your own if you're handy), and a portable either solar blanket or goal zero solar briefcase (less secure and easy for someone to walk off with if you aren't around the truck, and requires good light). If you went small enough you could keep it around $1,000 I think but likely a little over. Good news is they are all useful items that last.
    I can run a toaster and a larger dometic off my goal zero 500x lithium. But you'll need to do some maths to suit your needs. The best solution is go dual battery with a dedicated aux battery (I have an AGM) with solar panels on roof racks etc. to top off and keep it constant when you need. But it gets pricey too and is significantly more work. Good luck!
    drewskie[OP] likes this.
  11. Nov 20, 2021 at 3:56 PM
    #51
    drewskie
    Drew
    Burbank, CA.
    That definitely seems like a lot more work and money than I was trying to invest. And since I am in Los angeles, the equipment would probably be gone by the time I got back to the truck the first day. But I guess there would be a lot of sunlight would be the only Plus.
    tcjacado likes this.
  12. Nov 20, 2021 at 5:51 PM
    #52
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Why not just a couple of ice packs and a 12v toaster? If you're just trying to keep frozen waffles from spoiling for 8 or so hours that should do the trick.
