Best way to protect new headlight housing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wmb67, May 25, 2024.
  1. May 28, 2024 at 9:36 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
  2. May 29, 2024 at 6:29 AM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Lady Taco…
    :drool:
  3. May 29, 2024 at 10:00 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    My taillight housings ('14) are clear plastic and remain so to this day. Same outdoor environment as the headlights (that went so bad as to be useless in 7 years). Manufacturers know how to solve the headlight haze issue - use a different product ......... DOT could solve this problem by refusing to certify improper materials.
    Sidney Vicious likes this.
  4. May 29, 2024 at 10:10 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Do your tail lights get as hot as the headlights though?
    I agree they can figure out a better clear plastic to use for headlights, but when comparing your current HLs to TLs, factor in that HL lenses are putting up with 65w of trapped heat as well.
  5. May 29, 2024 at 10:17 PM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    My headlight housings don't get near as hot operating as they do when sitting in the Arizona sunshine - and I virtually never operate them in daylight to double up. Using the wrong material for manufacture is an easily identified engineering problem.
    Glass would work - and it is actually recycle-able.
  6. May 29, 2024 at 10:55 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Is it a spray, a gel, or an actual sheet of some form of plastic?
  7. May 29, 2024 at 11:21 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    THinking I need to do this again, mine are old and I can buff them but want to seal them with something afterwards.
    I know the original post is about new housings, if I were to give my old ones a good cleaning/buffing would the film work?
  8. May 30, 2024 at 1:41 AM
    EL DUDE
    EL DUDE Well-Known Member
    But damn if the headlights aren't brighter
  9. May 30, 2024 at 6:40 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    It's a clear adhesive sheet... use a spray bottle of soapy water like installing a decal. Used to be pretty thick (around 1/8") and hard to apply... needed a head gun and alot of patience. The older version was advertised to be able to take a rock hit without damage to lens. The newer Xpel is alot thinner material (around 1/16")... way easier to apply... just hope it works at least half as good as the original.
  10. May 30, 2024 at 8:26 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Everyone who has to replace headlights because the lens haze over should submit a claim to the NHTSA. Sure one won't make a difference, but if they start seeing enough they will look into it because it does become a safety issue.
    https://www.nhtsa.gov/
  11. May 30, 2024 at 9:13 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    I think that is pretty wishful thinking. Parts wear out and need replaced. Unfortunately headlights fall into that category. Plastic degrades over time when exposed to elements. Glass is no longer a viable option due to cost. Granted the 2nd gen isn’t an intricate design but some of the newer vehicles the size of the housing is astronomical and the design itself is part of the styling. We grip about our housings costing 300$. Could you imagine if it was glass and they were charging 600$ or 1000$ a piece?
    Could they find a better plastic? Maybe. Would a different plastic more resistant to wear cost more? Better believe it.
    Would you rather spend an extra 50$ on protection over the course of 15 years or pay an extra 3-400$ a piece extra for a better material that last the same duration as a “protected” housing?
    My headlights are original. 11 years old. Still look brand new. Truck is parked outside 24/7, 365. Total cost to keep them in shape. 40$ and two hours of my time.
    Island Cruiser and spitdog like this.
  12. May 30, 2024 at 10:39 AM
    dtaco10
    Dave
    Yes wishful thinking, but how hard would it be to design a glass insert into a plastic housing where the light is needed to reflect to the road?
  13. May 30, 2024 at 10:52 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    What is your method? Thanks
  14. May 30, 2024 at 11:06 AM
    dtaco10
    Dave
    If they can make windshields/windscreens and rear windows out of glass formed just to about any shape a vehicle body is and seal them so water doesn't penetrate the passenger compartment, I think they could do the same with headlights at a reasonable price if the designers set their mind to it. It is just a matter of thinking out of the box. I see nothing wrong with a plastic housing that has a glass insert sealed to the plastic.
  15. May 30, 2024 at 11:28 AM
    #35
    Steelhead Bum
    Mitchell
    Eastern WA
    Regular high quality wax twice a year when I wax the whole truck. Spring and fall. That’s in addition to regular washing in between. I like to think it keeps oxidizing to a minimum. Unkept paint on these trucks oxides pretty quickly, at least 040 trucks do. And Ive used the cerakote kit twice. First use was when the headlights just started to show signs of oxidation. First treatment lasted roughly 2.5 years. Just did the second treatment last month. If it last 2 years again I’d be happy.
    Cerakote kit is 20$ at Walmart.
    If I was starting from scratch with brand new housings I’d probably do the laminate suggested and replace it when necessary.
  16. May 30, 2024 at 11:50 AM
    #36
    spitdog
    Thanks, I may need to try that cerakote. Mine sits outside since new, always kept it waxed and clean like you. But now jut the very top of the lenses are starting to fade and they look like they have small scratches . I was thinking about buffing out those scratches and then apply that cerakote. I have used that turtle wax shine and seal, also 303, and think it’s about due for a little more work.
    Steelhead Bum[QUOTED] likes this.
  17. May 30, 2024 at 12:06 PM
    #37
    Steelhead Bum
    Mitchell
    Eastern WA
    That’s where mine started too. The cerakote kit uses a wet sand method so it would likely buff those scratches out in the process. Then uses a ceramic sealant to restore and protect. Think they have some videos of how the kit works. Check them out and see if it’s something that would work for you. Definitely not a permanent solution but for me it does the job.
    spitdog[QUOTED] likes this.
  18. May 30, 2024 at 8:59 PM
    #38
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    Like I reported earlier - the tail-light lenses on my '14 are clear - original - exposed to the same environment - and they don't have the cloudy scum that appeared on my headlights.......... The headlight problem is a "found" parts sales item being perpetuated by the Toyota parts sales group. I've been in the product engineering game for many years - mining and construction equipment. When we found an item that needed attention - that the parts management considered a "golden egg" - engineering changes would often be shelved "for economic reasons" they cited. This has put "will fitters" in business - and let them fleece end users with sub-standard replacements - which you will often see reported on this site.
  19. May 31, 2024 at 1:01 PM
    #39
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    or drive in direct sunlight
  20. May 31, 2024 at 4:34 PM
    #40
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Taillights are made from polymethyl methacrylate (PMMA, the same stuff as in Lucite/Plexiglas/Perspex). It's a highly UV-resistant polymer with extremely low moisture absorption. A great choice for exterior exposure.
    Headlights are made from polycarbonate (PC, the stuff in Lexan/Makrolon/others). It's a terrifically impact-resistant polymer, which is why it's specified. But it has marginal at best environmental resistance. In particular, polycarbonate is sensitive to crazing when exposed to moisture. A lousy choice for everything but impact, frankly.
    Where my rear gets roasted is that the manufacturers and OEM suppliers, who know ALL OF THIS, of course, haven't come up with better coatings to protect the polycarbonate. Seems like that technology is already there, but for some reason not applied to this problem.
    Too Stroked likes this.
