Best way to remove evaporator?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TX Tacoma, Sep 22, 2012.
  1. Sep 22, 2012 at 4:14 PM
    TX Tacoma
    TX Tacoma [OP] Fightin Texas Aggie
    Arlington, TX
    My compressor grenaded and I'm replacing my compressor/condenser/expansion valve/evaporator and flushing the lines.
    The Haynes manual doesn't cover replacing the evaporator or expansion valve, but I see that the evaporator is next to the heater core. To gain access to the heater core, Haynes recommends dismantling the dash (which I've already done) and the next steps are to remove the reinforcement brace (steel tube spanning the passenger compartment) I've already come pretty far with the disassembly, so I'm prepared to take this next step, but I'd rather not if I don't have to.
    Is there an alternative?
  2. Sep 22, 2012 at 5:53 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    wow. i have no idea, and am not sure many people on here would. i wouldnt even know how the txv is attached. is it brazed? flared connections? please keep this updated as this information will be gold someday when the rest of us blow up our ac
  3. Sep 22, 2012 at 7:09 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I don't have experience but here's a FSM link that might help:
  4. Sep 22, 2012 at 7:37 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Flush the condensor and the high side lines up to the receiver/dryer, replace the receiver dryer and compressor, and vac/charge the system.
    The receiver/dryer is a glorified filter, so any contamination from a failed compressor won't have reached the TXV and evaporator.
  5. Sep 24, 2012 at 11:13 AM
    TX Tacoma
    Arlington, TX
    I hit my tolerance limit on how much further I was willing to disassemble the cab to get the evaporator out, so I decided to flush it in place.
    I was able to flush the evaporator through the high and low pressure ports at the expansion valve at the firewall. I got alot of grey matter (metal FOD) out of the evaporator. This undercuts the argument that the accumulator is a very good filter when the compressor craters.
    Sidenote: I will outline this procedure in a future post.
    EDIT/UPDATE:
    After looking at it further, I realized that I didn't remove the refrigerant filter prior to flushing. Every other vehicle manufacturer calls it an orifice tube, but Toyota calls theirs a refrigerant filter. I found this out by trying to get one at Autozone and them finding nothing after searching for "orifice tube". I called Toyota and they told me it's listed as a "refrigerant filter" (just in case anyone ever tries to replace theirs and are told that the Tacoma doesn't have one).
    When I was flushing in the reverse direction of flow (through the low pressure side to the high pressure side) the debris that I collected with the flushing solution was actually debris that was caught by the filter after it left the compressor and headed down the high pressure line towards the evaporator, not debris from the evaporator.
    After removing the filter and then flushing further, I saw no debris from the evaporator. I'm confident that the filter caught most or all of the debris from the failed compressor and therefore, flushing the evaporator is sufficient and removing/replacing it is unecessary.
    The filter was completely covered with FOD, so either the accumulator/drier didn't do much of a filtering job, or maybe it caught all the big pieces and the fine stuff got through to the refrigerant filter. Without the filter, I'd definitely be taking the additional steps in cab disassembly to replace the evaporator.
    raycox4385 likes this.
  6. Sep 16, 2016 at 11:43 AM
    raycox4385
    raycox4385 Well-Known Member
    Ray
    Louisana
    2007 tan 4dr 4wd
    6" Rough Country Lift, 35" Nitto Mud Grappler, 17" XD Series rims, Chrome Nurfs, K&N, ANZO USA, HEADLIGHT, OPT7 LED HEADLIGHT AN PODs , FAB FOR REAR BUMPER, T-REX GRILL, Smittybilt (98510) X2O Waterproof Synthetic Rope Winch, ROAD ARMOR FRONT BUMPER an 50" curve AuxBeam light bar
    Were you able to get to the filter that's before TXV from the firewall on the engine side you still have to move the dash to get to that
  7. Sep 16, 2016 at 3:57 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  8. Sep 17, 2016 at 5:05 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    Thanks for the help an the link.
  9. Sep 17, 2016 at 5:15 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    receiver dryer removes moisture and protects the compressor from liquid while charging.
  10. Sep 17, 2016 at 5:39 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    I've already replaced the condenser which has the filter drier built into it still having the partial blockage. Low suction pressure high head pressure
  11. Sep 17, 2016 at 5:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    It has an expansion valve, correct? In the area of the evaporator?
    I've never heard of having an 'oriface tube' and an expansion valve in the same system. The oriface tube was the replacement for expansion valves in US systems back in the 80's.
    All the Japanese cars I've worked on continue to use an expansion valve.
    I suspect Toyotas term, filter, is correct, as that is the purpose it serves.
    And you are correct, the accumulator (formerly known as receiver/dryer) doesn't capture 'much' debris. It contains decadent, for the purpose of containing moisture.
    I'm wondering if your expansion valve has failed, thus causing your current issue.
  12. Sep 17, 2016 at 6:08 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    Seems like the TXV is probably stuck usually when the power head fails it's a complete restriction. Mine is just a partial
  13. Sep 17, 2016 at 6:10 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    Unless there is a inline filter before before the txv. Kind of Cloudy some people say there is some people say there isn't.
  14. Sep 17, 2016 at 6:15 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I had no idea AC system was so complicated. Hope I never have to work on mine!
  15. Sep 17, 2016 at 6:15 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    I think Toyota really dropped the ball on this one they could have easily put the TXV on the outside of the firewall
  16. Sep 17, 2016 at 6:26 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    What the hell is a,"TXV"? Are we just making up names for parts of the a/c system?
  17. Sep 17, 2016 at 6:40 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    The TXV is a proportional valve. When there is a high load it feeds more freon to the evaporator when there is a low load it feeds less freon.
  18. Sep 17, 2016 at 6:51 AM
    gottaToy
    JJ
    1985 Moped
    Why don't you just call it what it what most are familiar with, an expansion valve? Are you showing off by using abbreviations for Thermal Expansion Valve to feel smarter? If you are, you should use the term, "refrigerant", not freon.
    For warranty on a new compressor, expansion valve and receiver/dryer(accumulator) have to be replaced along with new compressor. Absolutely no reason to change evaporator or condenser unless there is a hole in one of them.
    Hobbs likes this.
  19. Sep 17, 2016 at 7:02 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    Not really showing off but sense spending the last 35 years plus in the residential, commercial air conditioning field
  20. Sep 17, 2016 at 7:04 AM
    raycox4385
    Ray
    Louisana
    2007 tan 4dr 4wd
    You u learn to talk a certain way.
