Best Way to remove rear lift blocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexlopez123, Sep 20, 2017.
  1. Sep 20, 2017 at 3:33 PM
    Alexlopez123
    Alexlopez123 [OP] Well-Known Member
    Alex
    2006 silver Tacoma 4x4
    Does anyone know what is the best way to take off the rear lift block or the safest way to do it
  2. Sep 20, 2017 at 10:00 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Jack the truck up and lower it back down onto the frame via jack stands. Remove the rear tires. Take your floor jack and then put it under the rear diff and jack it up until it supports the axle. Take off the u bolts on one side and lower the axle a bit via the jack. The axle will lower away from the springs on that side, and allow you to slip out the block. You'll need roughly and inch to clear the pins for the perch and springs. Now you can jack it back up and re-install the u bolts, and repeat for the other side. That's it in a nutshell. Watch a youtube vid if you need more of an eyes on tutorial. You can do both side at the same time if you want, just make sure you can maintain control of the axle housing if you loosen both sides at once.
    lo2hi and Silverspool like this.
  3. Sep 20, 2017 at 10:13 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    theres only 1 way, and thats how TxFireman stated.
