Best way to run wires from bed to engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Mar 12, 2024.
  1. Mar 12, 2024 at 5:29 PM
    iJDub
    iJDub [OP] Well-Known Member
    I have some lights in the back near where the bed meets the firewall. I need to run that up front to the engine bay battery area. What's the best route to take?
  2. Mar 12, 2024 at 5:32 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Inside the frame rails. :)
    FishingInSand likes this.
  3. Mar 14, 2024 at 2:40 AM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Yeah what he said, I have a air compressor in the bed and ziptied them inside the frame rails attaching to the existing lines for fuel and what not. With that distance just make sure you have the right gauge wire, no problem
  4. Mar 15, 2024 at 1:05 PM
    iJDub
    Thanks everyone!
  5. Mar 15, 2024 at 4:31 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I ran a circuit from the bed up to the fire wall, it's tough avoiding being near the manifolds if it's a V6. After seeing the factory wiring in the same area with it's heat protection I wrapped the wires in foil tape, it's not as nice as the factory did it. I were to do it again I'd start at the front and install the heat protection prior to trying to do it laying on my back under the truck lol.
