best way to sharpen a knife
Discussion in 'Off-Topic Discussion' started by eric3187, Mar 2, 2013.
  1. Mar 2, 2013 at 6:03 PM
    eric3187
    eric3187 [OP] Well-Known Member
  2. Mar 2, 2013 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Stones give the best edge. Lanski makes a nice ston set, and its almost fool proof.
  3. Mar 2, 2013 at 6:07 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Holy shit when I saw you replied in this thread I expected you to describe some 3-tool, 30-volt, 27,000 rpm contraption that can sharpen 7 knives in 3.2 seconds.
  4. Mar 2, 2013 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Woud burn the blade if you use a tool like that...:eek:
  5. Mar 2, 2013 at 6:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Stone then strop
  6. Mar 2, 2013 at 6:12 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2 on the Lansky setup. It makes it much easier to get consistently sharp knives. No more guessing at what angle to hold your knife.
  7. Mar 2, 2013 at 6:16 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Being an old meat cutter,I would use what we call a tri stone then use a diamond steel along with a regular steel.the blade has small teeth on it and the regular steel will line up the teeth after using the tri-stone and diamond steel back to normal as possable. good luck
    http://www.sharpeningsupplies.com/Norton-Sharpening-Systems-C65.aspx
  8. Mar 3, 2013 at 9:13 AM
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    The very best way to sharpen a knife.
    (1) Get one of these
    (2) Get one of these
    (3) Watch and learn.
