best way to wire from cabin to engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaimeDawg, Apr 9, 2012.
  1. Apr 9, 2012 at 10:44 PM
    JaimeDawg
    JaimeDawg [OP] make me a sammich
    Jaime
    Las Cruces, NM
    2011 trd off-road prerunner custom paint
    black saphire metalic paint with TRD off-road chameleon, 8000k hids on headlights and fogs, led map lights, led corner lights, saftey first baby seat mod in backseat, white/amber drls, devil horn emblems, trd seat covers, trd cai (old version)
    whats the best way to wire something from my engine bay to the cabin under the dash.. which will be well hidden. ill be installing leds on my 2011..any info will help
    thanks
  2. Apr 9, 2012 at 10:46 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Look at your fuseblock in the eng bay and follow it to the rubber grommet in the firewall and run the wire through there and up under the dash
    bigmw likes this.
  3. Apr 9, 2012 at 11:17 PM
    JaimeDawg
    Jaime
    Las Cruces, NM
    alright ill take a look at it tomorrow.
    thanks
  4. Apr 9, 2012 at 11:51 PM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    That's how I did it. That's your wire loom firewall boot. I used a metal hanger and taped the wire to it and threaded it through the boot from the engine bay. Once you get that first wire through any additional wires seem to thread through with less effort. :)
  5. Apr 10, 2012 at 12:12 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    I jsut stabbed the grommet meat with a knife and shimmied the wires I needed that way using a stiff pilot wire cause I was too last to go find a coathanger lol but anything will work really its fairly simple
  6. Apr 10, 2012 at 12:13 AM
    Blueberry
    Nick
    Newton, KS
    LOL! Nothing wrong with the brute force method either.
  7. Apr 10, 2012 at 12:13 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  8. Apr 10, 2012 at 3:11 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    That's what I used when I jammed my coax cable through there... Of course a little soap would of helped. Funny how I thought about it after the fact. lol
  9. Apr 10, 2012 at 3:19 AM
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    Since we are on the subject. Sort of.... What's the best way to get from the cab to the bed, I need to run a coax for my cb antenna?
  10. Apr 10, 2012 at 3:25 AM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    there is a rubber grummet between the cab and the bed just on the left it comes in where youre truck jack tools are if you need pictures of how i did mine i can post them
  11. Apr 10, 2012 at 3:29 AM
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    You would be the man for that.
    Sorry for jacking your thread Jamie.
  12. Apr 10, 2012 at 3:36 AM
    jamtoz
    jamtoz frog
    James
    Quebec
    ok ill take the pictures as soon as i get back from the job ;)
  13. Apr 10, 2012 at 3:41 AM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    tnx guys this will help 4 future mods:cool:
  14. Apr 10, 2012 at 4:54 AM
    DueNorth
    When I had my antenna mounted off the box I ran the coax through a rubber grommet underneath the drivers seat.
  15. Apr 10, 2012 at 11:04 AM
    JaimeDawg
    Jaime
    Las Cruces, NM
    lol no worries..I got the info i needed :D
  16. Apr 10, 2012 at 3:51 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    +1
  17. Apr 10, 2012 at 4:12 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    on the first picture i am pointing at the place were the hole with the rubber is
    on the second one you can see were it comes in, i sealed it with flextra kinda of a messy job but you cant see it from youre house so its all good
    on the third one im pointing at were you have to pass it, might have to unclip the triming a bit
    then you unscrew the kicking board and put it underneath it
    then i point at were my wire is going under the carpet
    for the power i hooked it on a 15 amp accesory fuse so when i turn the key off the cb goes off(some people put it on the lights fuse or something and it always stays on)
  18. Apr 10, 2012 at 9:39 PM
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    +1. thanks a bunch.
  19. Apr 12, 2012 at 6:46 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    my pleasure, if you have other question just ask ;)
