Best way to wire this???
Discussion in 'Audio & Video' started by bendbolden, Sep 17, 2010.
  1. Sep 17, 2010 at 1:08 PM
    bendbolden
    bendbolden [OP] Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I just bought a set of kicker 6.5" componenets and a kicker amp with high level inputs to push them. What are your suggestions as the easiest way to get the signal to the amp. Should I buy the hi to low level adapter or run the wires straight to the amp. Also if anyone could point me to the wiring codes that would be great. I have an 07 reg cab if you are wondering. Thanks!
  2. Sep 17, 2010 at 2:18 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    if it has high level input just get the plug and tap into the speaker wires behind the radio.
    left front (+/-) pink/purple
    right front (+/-) lt green/blue
    left rear (+/-) black/yellow
    right rear (+/-) red/white
  3. Sep 17, 2010 at 2:18 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Also I plan on mounting this amp under the seat if that matters.
  4. Sep 17, 2010 at 2:20 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    ok. those are the codes I was looking for. I have always had bad luck doing it that way but if those colors are right then I should be able to do it. Any recomendations for wire gauges. I normally use the big stuff for my subs but don't have much experience with smaller stuff. 16 gauge?
  5. Sep 17, 2010 at 2:21 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    also this is a single cab so I assume the colors would be the same behind the radio with just the rear speakers not connected?
  6. Sep 17, 2010 at 4:27 PM
    t_e
    Erik
    miami,fl
    i used 18ga wire. wires are the same color, the rear speakers are on their own plug by themselves so maybe you wont have that plug since your single cab
  7. Sep 18, 2010 at 11:46 AM
    hoyta
    hoyta Well-Known Member
    Adam
    Camden,NC
    08 Rugged Trail DC
    Thanks for posting this! I was wondering as well the wiring
  8. Sep 23, 2010 at 8:18 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Just an update: bought a stinger LOC and it works great. Make sure it is grounded though or you might get a nasty hum.
