Best Weld-on sliders?
Discussion in 'Off-Roading & Trails' started by jspadaro, Oct 6, 2009.
  1. Oct 6, 2009 at 10:31 AM
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Looking for input on the best weld-on sliders. I've heard great things about shrockworks, but they take forever to ship and are bolt-on. All-pro's apparently bend when you actually use them.
    If I'm looking for some solid weld-on sliders, what's my best bet?
    Also, sometimes I'm able to order weld-on's powdercoated... How does that work, doesn't the welding ruin the powdercoat? :confused:
  2. Oct 6, 2009 at 11:14 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I'm sure there is more than one person who will recommend Demello's sliders.
  3. Oct 6, 2009 at 11:19 AM
    Snyperx
    Snyperx Seniore Marcos
  4. Oct 6, 2009 at 11:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I had a set of Demello Rock Crusher square tube sliders on my 96 tacoma. They were BOMBPROOF.
    Granted...How you get them welded to your frame can make a big difference in how they perform (and how the frame can withstand it).
    I had "L" brackets welded to the ends of the rock sliders (with gussets). The L brackets were placed up againest the frame and stitch welded to the frame.
  5. Oct 6, 2009 at 11:26 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    when powder coating or painting the person/people doing it should/will usually leave an inch or two bare at the welding point to get a clean weld. So, the paint doesnt ruin the welding. As far as which ones to go with, I just finished a similar search as yours. I ended up getting some from 4xInnovations. A member on here (FIRE931) has them and has reported excellent results after wheeling his truck pretty hard (as seen in his pics). They are relatively cheap compared to others on the market and, as mentioned, performance is good as well. Im actually getting mine today. Ill be painting them this week, and hopefully get them welded on this weekend. Ill try to keep you in mind and post pictures/results as the process goes on so that you have an option.
    I dont know if your set on getting them powder coated but the process usually runs about $100-$140 depending on the seller. IMO, and as others have suggested, using some Rustoleum is much easier and cheaper. When u bang up powder coating your gonna have a tough time getting them touched up as theyre welded on to your truck. You may be able to do Rustoleum with the powder coat but Im not sure the textures/colors will match.
    Just something to think about.
  6. Oct 6, 2009 at 11:28 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I guess too if I just rattlecan them now, I could always line-x/herculine/durabak/etc them later, right?
  7. Oct 6, 2009 at 11:31 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    yup.
  8. Oct 6, 2009 at 11:35 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    yup yup.. go with 4xinnovations! i'm running the DOM version with the kickout.. these things have taken beating after beating with no complaints... not to mention they have a great price on them as well! once you get them go ahead and paint everything but the mounting bracket... after you get them welded on then finish up the painting! i rattle can mine several times a year to cover trail damage and whatnot. i just cut up acouple trash bags, tape them to the side of the truck and go at it. and wa la.. brand new sliders again..
  9. Oct 6, 2009 at 11:37 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Cool beans. Has anyone had them linex'd? I'm thinking black linex would hold up better than paint, and provide a bit better grip to use them as a step bar in addition to a slider. Yes/no? Will the liner just scratch off at the first rock it sees?
    4xInnovations seems like the way to go, now I just have to figure out what to do for my front.
  10. Oct 6, 2009 at 11:38 AM
    Janster
    Jandy
    Lancaster, PA
    Use Herculiner for the tops & sides....and rattle can for the underside (where the rocks will bite).
    That's what I did....
  11. Oct 6, 2009 at 11:40 AM
    Fire931
    VA
    00 4Runner
    yea maybe putting something on the top would be ok for added traction when wet.. but the bottom is just gonna get scraped right off with the first rock.... i just rattle can all of mine, although i never step on mine either so it dosnt make much difference to me.
  12. Oct 6, 2009 at 11:43 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Well, I don't need to step on them, but girls could use them, especially if I go up in tire size in the future. :p Stubbs welding, I'll keep that in mind.
  13. Oct 6, 2009 at 11:46 AM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    X3 - Demello for the win.
    I have a set of double tube Demello's, my second set. I have Hi-Lifted them, dropped them on rocks, pivoted off them and basically abused them in ways that I can't describe on a friendly forum... I have barely scratched the powdercoat. No way of knowing how much damage they have save me from, but it's considerable.
    No reservations.
  14. Oct 6, 2009 at 11:46 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    All pro sliders are all HREW afaik (or at least their most common sliders)
    DOM > HREW.
  15. Oct 6, 2009 at 11:52 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'm running Shrockworks and they're extremely solid. Well worth the money, but possibly not the lead-time depending on when you expect to go 'wheeling.
  16. Oct 6, 2009 at 11:54 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    i don't have photo evidence, just what I've read about them in other posts on this forum. Never seen them in real life, I have no idea, that's why I say that's what I heard. :)
  17. Oct 6, 2009 at 12:12 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Still like my Stubbs Deluxe. More supports than the shrocks.
  18. Oct 6, 2009 at 12:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Gonna throw a X4 for the Demellos. I too, have heard of the All Pro sliders bending. To add, I belive All Pro has 3 mount points as opposed to 4...??
  19. Oct 6, 2009 at 12:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2
  20. Oct 6, 2009 at 12:39 PM
    Fire931
    VA
    00 4Runner
    well all i can say is i love my sliders.. they have 4 mounting legs, a nice kickout that i love to pivot off of... and are hella tough.. i'll take my $265 DOM sliders with a kickout over higher priced HREW kickout or not... and even if DOM is overkill for most people.. if you can get overkill for a better price... why not???
    note... i'm not arguing with anything anyone says.. just pointing out the facts...
