BEST WIPER BLADES
Discussion in 'Product Reviews' started by hotrod45, Nov 1, 2011.
  1. Apr 10, 2012 at 10:37 AM
    #61
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Ill grab a shot of the toyota ones when I can get to my truck. Stockers are under the seat
  2. Apr 10, 2012 at 10:40 AM
    #62
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Thanks for the help rugged t. I would appreciate a pic if you can get one.
  3. Apr 10, 2012 at 11:34 AM
    #63
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I am just an idiot I figured out what what it was. The clamps on the frame holding the insert in were just loose causing the rubber to slide and allowing the metal inserts to slide. I just had to squeeze the clamps down. I feel about a million times dumber right now.
  4. Apr 10, 2012 at 11:37 AM
    #64
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Even the Goodyears. The heat out here cooks the living shit out of them.
  5. Apr 10, 2012 at 6:08 PM
    #65
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Good job figuring it out
  6. Apr 10, 2012 at 6:13 PM
    #66
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    About a year ago I bought some silicone wiper blades. They seem like a good idea. After a while, they started to jump across the window. I don't know what the proper term is. So I ditched them for some Teflon-coated one-piece blades.
  7. Apr 12, 2012 at 7:32 PM
    #67
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    I have had Bosch Icons for about five months now and they are still holding up well. Worked pretty good in the winter, keep in mind I did try to remember to lift them up when is was going to snow. Spring as sprung and still no problems. We'll see how long they last.
  8. Apr 13, 2012 at 8:11 AM
    #68
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I've been in the rain a couple times with them so far. They are much better than the Rain-X blades I had.
    Isn't is recommended to change blades everything 6 months?
  9. Apr 13, 2012 at 8:17 AM
    #69
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    My OEM blades were on the truck for 3 years before they stopped performing...
    There probably is a 'recommended' service life to wiper blades but to me, blades are something that should get changed out based when they stop performing, not based on duration.
  10. Apr 13, 2012 at 8:41 AM
    #70
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Michelin hybrids from Costco. Best thing since sliced bread for blades here with winter. Great for in summer, and they don't gum up when the snow and ice hits, and they don't lift like with regular winter blades.
    OhioTaco68 likes this.
  11. Apr 13, 2012 at 12:10 PM
    #71
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Now that I fixed my stop wipers ( I kick myself every for how stupid I am ) they work flawless. My PIAA wipers come in next week. During the first heavy rain I will try them both and and give a detailed review. I might put one of each wiper on for a true comparison.
  12. Apr 13, 2012 at 1:41 PM
    #72
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks 4 the update:D
  13. Apr 13, 2012 at 1:42 PM
    #73
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    michelin FTW
  14. Apr 16, 2012 at 12:32 PM
    #74
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    For those of you with the PIAA bladed did you need the adapter or just slide it on the hook? I have not opened the package yet but it looks like it just slides on. Dont want to force it on there just to mess it up.
  15. Apr 20, 2012 at 10:26 AM
    #75
    VA7FQT
    VA7FQT Toyoda
    Kyle
    British Columbia
    2014 DCSB 6spd
    D60 Front, Shaved 14 Bolt Rear.
    PIAA, get PIAA.
    A little more expensive than the competitors, but head and shoulders above the rest.
    For install, just match the wiper you took off to the hook/adapter that looks the closest. It takes a little bit of pressure to attach. But not much.
  16. Sep 19, 2012 at 5:57 AM
    #76
    WebRat
    WebRat Active Member
    Oregon
    2012 Taco Sport
    Removed badges, Tinted windows, Tube steps, Leveling lift, Brush Guard.
    I have not used Rain-X in years, to me it seemed to shorten the life of the wiper blades so I stopped using it. I might pick up and try the "Rain‑X Washer Fluid Additive" and see how that goes. So far 11 months on OEM wipers and still going.
  17. Sep 19, 2012 at 5:43 PM
    #77
    george3
    New Jersey
    I just put on the Bosch Icons. Had Trico - they were not worn out but drivers side chattered - annoying. How is the longevity on these ??
  18. Sep 23, 2012 at 9:18 AM
    #78
    WiscTaco
    Wisconsin
    Sr5 Trd 23.42 mpg
    The Bosch Icons on my truck have held up relatively well. They are roughly a year old and are starting to streak somewhat. The streaks however are still the fine trails of water, instead of big globs of water.
    Aquapel
    is what I use for washer fluid. I used to be a RainX guy but thought it was time to see what else is out there. Not too bad, eats away at about 90% of fresh bug splatter and 100 for dust. The streaks didn't start occurring till I started using Invisible Glass with water repellent. In the rain it seems there is a "film" on the glass that doesn't mesh with the Bosch Icons.
    Conclusion. Fan of the Icons, Aquapel- might try more of their products, especially since I need to find a replacement for invisible glass.
  19. Sep 23, 2012 at 11:09 AM
    #79
    george3
    New Jersey
    Had rain last week. No more chatter. Cleaned windows fine. Time will tell on the longevity.
  20. Oct 20, 2012 at 11:05 AM
    #80
    WiscTaco
    Wisconsin
    Sr5 Trd 23.42 mpg
    Update with Aquapel products.
    They have a glass treatment product that is advertised to chemically bond with glass, creating a rain repellant surface for up to six months.
    The steps required are fairly straight forward. For those that might use this product, make sure the glass is exceptionally clean before you apply the glass treatment and you have plenty of shop rags/paper towels at your side.
    After applying the glass treatment I noticed an immediate improvement. It drastically out performs Invisible Glass with rain repellant glass cleaner. During rainfall, water beads much like it does on a nicely waxed car. At speeds over 40 mph, the rain simply rolled over the windscreen. I find myself only having to use my wipers at low mph or when a quick "clear" view is needed (passing etc).
    Conclusion-Fan of Aquapel's glass treatment, we will see how long it last. The application process is somewhat tedious (making sure you get all the smudges out), but the end result far out weighs the cons. I am curious how it holds up to the ice and snow this coming winter.
    And no I do not work for Aquapel. I'm simply a consumer who is sick of buying bad products and will gladly spread the word if I ever come upon a product I like. Hope this was informative to some.
    mict450 likes this.
