bestop 3rd brake light question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jakeworthy, Oct 30, 2012.
  1. Oct 30, 2012 at 5:09 PM
    jakeworthy
    jakeworthy [OP] Well-Known Member
    Jake
    HB
    2019 DCLB
    hey guys, was hoping someone could point me in the right direction with wiring up the third brake light for the supertop. I know i need to tap into the tail light assemble, i just have no idea which wire to tap into. one white and one black wire run from the brake light. Let me know if any of you did this, and if you could give me some insight. thanks!
  2. Oct 30, 2012 at 5:16 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Jake, usually white is hot and black is ground...how many/what color wires come from the bestop light?
    EDIT: Check out this thread and see if it helps.
    http://www.tacomaworld.com/forum/2n...ring-third-brake-light-bestop.html#post774429
  3. Oct 30, 2012 at 5:44 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    One white and one black is what comes from the best top brake light. I just not sure what wire from the tail assembly to tap the white one into.
  4. Oct 30, 2012 at 5:48 PM
    The Traveler
    SoCal
    Third Brake Light>>>>>>>>>>>>>Tail light Wires
    White>>>>>>>>>>>>>Green/Red
    Black>>>>>>>>>>>>>>White/Black​
  5. Oct 30, 2012 at 5:55 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I'm not sure where bestop sources the light from but some companies in China use black and white instead of black and red. When the wires are black and white, black is usually hot and white is usually ground. That being said, the diagram above may still be correct depending on how the truck is wired. I have a wiring diagram but I'm not at home.
  6. Oct 30, 2012 at 6:01 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    So the black wouldn't get grounded to frame, it jut connects to black/white wire on the tail light?
  7. Oct 30, 2012 at 6:03 PM
    The Traveler
    SoCal
    That's my best guess. Either way, the black/white wire on the tail light goes to a ground. I'd splice it in with that wire just to be easier than finding a bolt that is a good ground to the frame.
  8. Oct 30, 2012 at 6:13 PM
    Drunknsloth
    Retribution
    South West
    http://www.12volt-travel.com/knowledgebase/led-lights-wiring/
    I would try testing them first.
  9. Oct 30, 2012 at 6:16 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    +1 on using a multimeter...from what i've notived, white is the ground on our trucks
