Bestop owners: quick question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Puppypolice78, Nov 13, 2013.
  1. Nov 13, 2013 at 1:53 PM
    Puppypolice78
    Puppypolice78 [OP] Active Member
    NC
    4X4 2.7L
    I've been looking at a Bestop for my reg. cab long bed and have seen a lot of pics on here of them installed.
    Half of the ones I see posted look good, taught and crisp, just like they do on the manfs. website. The other half look like flacid turds. The material is all wrinkly and wavy, along with the windows.
    Is this just because someone didn't take enough time to install it right, or is this just the way they look after being on a while? If so can they be easily retightened to look decent?
    Thanks in advance...
    Picture below shows what I'm referring to.
  2. Nov 13, 2013 at 1:56 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    subd i was just thinking about this looking through the soft topper thread
  3. Nov 13, 2013 at 2:09 PM
    Puppypolice78
    NC
    4X4 2.7L
    I have looked at those as well but don't dig the lack of windows. It makes our trucks look too much like a military vehicle out of WWII IMHO. :)
  4. Nov 13, 2013 at 2:41 PM
    Puppypolice78
    NC
    4X4 2.7L
    True, true...
  5. Nov 13, 2013 at 7:35 PM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    just got my bestop the other day for my 06 access cab 6ft bed. It is super tight and looks like the upper half of the pic you have. On the directions it says at first they can be a little wrinkly or have creases but they should come out after a few days of use. I couldn't get the windows in cuz its 30* out and they recommend install above 72* otherwise the fabric can shrink and be hard to work with. I don't plan on putting the windows in until it warms back up only cuz a lot of people say they can break easily in the cold. Other than that I think it looks awesome. Defiantly one of the best things I have bought for my truck so far. Hopefully this was helpful and good luck with your decision!
  6. Nov 13, 2013 at 10:54 PM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    i dont have for my toyota, but for my CJ7, i have one made by best top, they key is to NEVER ROLL the windows, completely unzip and lay flat, it can seem like a pain sometimes, but you get in the routine, they will stay like new and crisp, if you roll them up they get scrstched, stretched, discolored, ugly. the top itself at least for the jeeps, it will be snug at first but you will see where it kinda breaks in, like some new shoes i guess, just when you put it up have the bars in those 'broken in' spots, its when do it in a hurry and things arent just right but you force it that you se the stress places and stretches and stuff at least from what i have seen.
    no, once it starts to kinda frey i guess you could say there is little you can do to kep it taught, there are some different notches, at least on the few i have had on my jeps over the years, that allow tightening by changing length of the bars, but i find thats mainly for just getting it broke in, when you try to compensate for it coming apart or stretched out, its just a matter of time really
    hope that helps, i know its not for your truck, but mayabe at least give some info on the manu
    cheers,
    disco
    hope that helps
    cheers,
    disco
    ---------------- edit/side note ---------------------
    CLEAN THE ZIPPERS before zipping and unzipping if you been in mud or sand if possible, you know what i mean, if your on a dusty trail its fine, you go through a bog or clay make sure you at least clean them up some what, helps ALOT to keep things working smoothly, also, again not sure if its exactly the same but when folding and unfolding, put the main part up first, make sure the bars are on the pads then tighten up, then zip on your side windows, on those probably 3 sides, then the bottoms if they like jeeps are kinda like long clips i guess you would call it, stretch the bottom and clip in
  7. Nov 13, 2013 at 11:09 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Here's mine:
    Don't see a problem...they're not super straight because it's not suppose to be like that
  8. Nov 14, 2013 at 2:52 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I have a bestop and it was a bitch putting it on.. In any case I'm super happy with it. It is super tight and it protects my stuff in the bed from getting wet.
    I never roll the windows. I simply remove them. They don't look like a flaccid turd. Haha
    I'd reccomend anyone to get one if it fits your usage of the truck of course
  9. Nov 14, 2013 at 3:22 AM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    get one look at my sig for one without the windows on...
