Bestop problems. Need help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by agroman2001, Jan 31, 2011.
  1. Jan 31, 2011 at 10:34 PM
    agroman2001
    agroman2001 [OP] Member
    AJ
    San Diego
    07 TRD Offroad 4x4
    Ready Lift leveling kit, Smittybuilt light bar w/ 4 Hella 500s, Grillcraft black mesh grille, painted the rear bumper plastics and Hella light covers with bed liner, custom whip mount w/ green Safeglow 200 LED whip, rear dif. breather relocate
    Just got my bestop soft top camper shell and im installing it. Got it all up, got the rear window on and started to install the side window/panels. Im going by the directions. I get the top conected and one side with the zipper. Then wheni attempt to engage the zipper on the other side there's a good 3" gap between each side of the zipper. I've tried everything I can think of to connect the two and am finding it impossible (at least by myself it is) has anyone else had this problem when installing theirs? Any suggestions?
  2. Jan 31, 2011 at 10:38 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    What's the temperature outside? Heat helps.
    That is if it is a stiff canvas issue.
  3. Jan 31, 2011 at 10:41 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    If you have access to a fabric steamer, it can work wonders. I was in the automotive upholstery bussiness for many years doing convertible tops and a steamer was my #1 tool.
    If it's warm enough outside, lay the top on the blacktop or asphalt for an hour.
  4. Jan 31, 2011 at 10:51 PM
    agroman2001
    AJ
    San Diego
    07 TRD Offroad 4x4
    Definitely cold out. Probably going to give up tonight and try again tomorrow.
  5. Jan 31, 2011 at 10:57 PM
    wolfdog2314
    Brush Prairie
    You'll read a lot on here about people having a lot of issues installing the besstop in the cold.
    Find a warm shop, or wait till a blue bird day.
