Better 5 sp trans lube
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KentuckyEd, Mar 10, 2011.
  1. Mar 10, 2011 at 8:50 AM
    KentuckyEd
    KentuckyEd [OP] Member
    Ed
    Louisville, KY
    2012 std cab 4X4 2.7L auto
    Just finished my 30,000 mile service on my 2007, 2.7 litre, 4X4, std cab. I installed all Red Line synthetic fluids (75W90 gear oil in diffs and transfer case) and MTL in the transmission. If anyone has a real notchy transmission, especially going into second gear, I highly recommend this fluid. In my previous life as a Miata driver this fluid was well known to improve the notchy Miata gearbox and it has done wonders for my Tacoma.
    The improvement was very noticeable and immediate after the fluid change. I've only owned this truck since last Nov and only put 1,800 miles on it, but during all of that time the trans was a real PITA, especially when cold.
    So if you'd like to make your trans a bit easier shifting try the Red Line MTL. You can google it to find out all about it
  2. Mar 10, 2011 at 11:45 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    I used Redline MTL in my 52 MG TD tranny & what a great difference!! Shifts really smooth for a 59 yr old car. I will put it in my 08 Prerunner when my warranty expires.
  3. Jan 20, 2017 at 6:43 AM
    jrsimon
    jrsimon Member
    john
    columbus, ohio
    2010 Tacoma
    My 2010 5 speed Tacoma with 60K had notchy shifting going from 1st to 2nd and some to 3rd. Red Line PT90 synthetic made a very noticeable
    difference. Also Klasse All-In-One polish available from Auto Geek is by far the best wax/polish I have ever used. Lasts a LONG time
  4. Jan 20, 2017 at 6:53 AM
    timothom
    timothom Well-Known Member
    Tim
    Western Montana
    2014 Tacoma Access cab sr5
    Clarion VX404 Alpine PDR-f50 Alpine type-r 8" JL audio TR-650ci
    I used MT-90 in my 6 speed, and I noticed a big difference. Is MT-90 the same thing as MTL?
  5. Jan 20, 2017 at 6:59 AM
    jrsimon
    jrsimon Member
    john
    columbus, ohio
    2010 Tacoma
    I apologize, it was Red Line MT-90 oil I used and not PT-90
  6. Jan 20, 2017 at 7:02 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
  7. Jan 20, 2017 at 5:47 PM
    1320Fastback
    1320Fastback Active Member
    05 4.0L 6spd
    No, MTL is 75W80 GL3/GL4 and MT-90 is 75W90 GL4.
