Better Ball Joint help??
Discussion in '1st Gen. Tacomas (1995-2004)' started by tmolina, Dec 18, 2009.
  1. Dec 18, 2009 at 6:57 PM
    tmolina
    tmolina [OP] Well-Known Member
    Thomas
    AZ
    '02 Tacoma dbl cab Prerunner
    2 inch lift with SAW's on front, AAL on rear
    What is the most durable aftermarket upper ball joint on the market? I can't afford new UCA's now but want a better ball joint to go with my OME coilovers on 98 Tacoma Prerunner almost 3" of lift. Looking for something to give me piece of mind with extreme angle. Thanks
    Thoma
  2. Dec 18, 2009 at 6:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You need a Uniball. Only available on new UCA's. Otherwise, most all ball joints are made to OEM specs.
  3. Dec 18, 2009 at 7:10 PM
    tmolina
    Thomas
    AZ
    Thats what I was afraid of. Guess I will have to save up for LR UCAs that are supposed to come out mid January for 1st gen's. Or find some good used ones;)
