Better Bed Lights!
Discussion in 'Deals & Coupons' started by TacoStandCT, Oct 20, 2015.
  1. Jan 3, 2016 at 8:58 PM
    #141
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    I saw on the first page (sorry didn't read all other 7 pages) where someone had mentioned making them for trucks with camper/caps... I have recently installed an Leer topper. With the reduced visibility this would be great for backing up with some extra light
    TacoStandCT[OP] likes this.
  2. Jan 3, 2016 at 9:11 PM
    #142
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am VERY interested! I have been wanting to do some sort of bed lights for a long time. This looks like a perfect solution with little to no compromise utlizing the existing OE appearance.
  3. Jan 5, 2016 at 10:35 AM
    #143
    TacoStandCT
    TacoStandCT [OP] Well-Known Member
    CT
    2007 Tacoma TRD Off Road
    Thank you for the interest and feedback. The truck caps are certainly something that is growing in popularity based on the feedback I have received. My focus will be to get these on the 1st and 2nd gen's then I will look into what modifications can be made to make it fit the camper/cap crowd.
  4. Jan 5, 2016 at 11:28 AM
    #144
    AKTACOTRUCK
    AKTACOTRUCK Well-Known Member
    Shawn
    Red 2008 Tacoma TRD Offroad Double Cab
    Bull bar, but more to come
    sub'd! Sweet setup:popcorn:
  5. Jan 5, 2016 at 7:38 PM
    #145
    TacoStandCT
    CT
    Just posted Part 1 to how I wired my truck, check it out here! :taco:
    ChadsPride likes this.
  6. Jan 5, 2016 at 7:48 PM
    #146
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    @TacoStandCT - is there a best method to pull out the light base and remove the sticky gasket?
    What minimum ambient temp is needed to get good adhesion for the gasket between the truck body and the provided plate?
  7. Jan 6, 2016 at 6:02 AM
    #147
    TacoStandCT
    CT
    Remove the Brake Light
    When removing the light and OEM gasket it helps if it is warm out , so if you have access to a heated garage that might be helpful. In order to pull the light base out you need to remove the screws and firmly but carefully pull the whole light assembly out. My OEM gasket ended up ripping in half when doing this (which is fine). It might be helpful to have two sets of hands so you can get your fingers behind it and pull the whole light at one time.
    Peal off the old gasket
    Once you have it off the truck I was able to just peel the old gasket off of the truck and brake light with my fingers. Most of the gasket came off in one piece and then I used goo-off for the small pieces of adhesive left behind. Once you are done you should have a clean truck and brake light surface.
    Apply new gasket to brake Light
    There should be one gasket already attached to the Better Bed Light bracket for you. There was another gasket that was provided, attach this one to the back of the OEM brake light assembly, it would probably be helpful to do this somewhere warm (like inside) for good adhesion. I will check with the manufacturer to see if they have recommended temperatures.
    Attach whole assembly to truck
    As far as attaching the whole assembly to the truck, it shouldn't matter what temperature you do this in. As you screw the Better Bed Light bracket and OEM brake light onto the truck with the new screws provided the gaskets will compress creating a water tight seal around the lights. You do not have to over tighten this to get a good seal. The gaskets will not be glued to the truck so you can remove the whole assembly in the future without ruining the gaskets if you would like.
    Please let me know if you have any further questions.
  8. Jan 7, 2016 at 3:10 PM
    #148
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I finally opened my better bed lights shipping box - VERY Nice quality @TacoStandCT !! Hopefully the weather will cooperate and I can get these installed next week.
    TacoStandCT[OP] and ChadsPride like this.
  9. Jan 7, 2016 at 4:32 PM
    #149
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    subed for later purchase
  10. Jan 19, 2016 at 7:46 PM
    #150
    kcalhoun27
    kcalhoun27 Active Member
    Kevin
    2015 ACLB TRD Sport
    None
  11. Jan 25, 2016 at 4:39 AM
    #151
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    any updates on getting the bracket powder coated?
  12. Jan 25, 2016 at 7:57 PM
    #152
    TacoStandCT
    CT
    We are not going to be providing any powder coating but we will be providing an anodized option with our next batch!:yay: We should have a new large batch of brackets in a few weeks so hang tight!
  13. Jan 25, 2016 at 8:56 PM
    #153
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    Very cool idea OP! I might need these soon!
  14. Jan 27, 2016 at 5:01 PM
    #154
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  15. Jan 30, 2016 at 12:06 PM
    #155
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    ok!
    put me down for the whole set up!
  16. Feb 1, 2016 at 1:39 PM
    #156
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    on a side note, where in CT are you from?
  17. Feb 4, 2016 at 5:35 AM
    #157
    TacoStandCT
    CT
    I'm in the Middletown area
  18. Feb 4, 2016 at 6:13 AM
    #158
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Sub'd and waiting for additional finish options.
    Very cool.
  19. Feb 5, 2016 at 2:37 AM
    #159
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    Wethersfield
  20. Feb 6, 2016 at 4:54 PM
    #160
    Loudass Arod
    Loudass Arod Active Member
    A-ROD
    St. Petersburg, Fl
    2015 Tacoma TRD Sport 4x4 long bed
    Thule Truck Rack, tow package, front seat covers, indoor/outdoor carpet for the lay down of the bench seats.
    I'm in for the next batch!
