Better Dessert leaf pack
Discussion in 'Suspension' started by mnudo200827, Jul 23, 2010.
Which is better for desert
Poll closed Sep 22, 2010.
  1. Deaver
    28.6%
  2. Alcan
    14.3%
  3. All-Pro
    14.3%
  4. Other...Please Specify in post
    42.9%
  1. Jul 23, 2010 at 8:33 PM
    mnudo200827
    mnudo200827 [OP] Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    Just wondering what would be a better dessert leaf pack for more higher speed stuff, i have only heard of deaver, alcan, and allpro. I am looking for about 3-4" of lift too. Does Deaver make a pack thats 3-4" or would i need a custom. I know i can get a custom one from alcan, and all pro doesnt offer a custom one but they have a 3" one. So for all you guys with experience with leaf pack which would you suggest. Thanks...Mike
  2. Jul 23, 2010 at 10:07 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    3 to 4 inch rear lift is high unless you are running 6 inches up front... in which case, you don't want to do any high speed desert wheeling with a drop bracket lift...
    if long travel up front, then you could do a 3 or 4" rear lift and it will sit level...
  3. Jul 24, 2010 at 8:54 AM
    mnudo200827
    Michael
    Corona, CA
    i might go long travel up front in the future, just a little to mch money for me right now, but right now putting on camburg spindles with extended coilovers.
  4. Jul 24, 2010 at 3:23 PM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    2014 Ford Raptor
    I wouldnt waste my $$ on a nice pack until you go spring under 62s. The packs cost the same amount but its night and night with a spring under setup.
    Do it once or two/three times to get it right. The choice is yours.
  5. Jul 24, 2010 at 9:56 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    x2
  6. Jul 25, 2010 at 10:18 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    OME Dakar 3" of lift and better flexability.
    Or custom built.
  7. Jul 25, 2010 at 10:21 AM
    mnudo200827
    Michael
    Corona, CA
    I thought the OME Dakars are more for hauling, I hearf they are stiffer than all the other leaf packs
  8. Jul 25, 2010 at 1:13 PM
    Masada
    Taylor
    Laveen, AZ
    I know a guy that's running them on his LT kit and loves them.
  9. Jul 26, 2010 at 6:27 AM
    mnudo200827
    Michael
    Corona, CA
  10. Jul 26, 2010 at 7:21 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    anything less than a SUA 62" leaf pack out back is just gonna buck like crazy
    even if you just have mid trav up front, and not LT
    trust me...
  11. Jul 26, 2010 at 7:37 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    You know when I see these kind of posts - You typically get what each poster has.
    I have the All Pro 3 inch. Off Road I think they are great. The problem is I know no different - other than the stock springs.
    When I worked at a Desert Proving Ground - we would go through 100s of whatever we were testing. The truck/car would be instrumented to detect movement, temperature, rate of change of movement, etc - then we would run over a test track that had exact replications of most major roads with unique characteristics - 405, Chicago Loop, etc., etc.
    This way you could find out if the set up would have a wicked isolation in some odd case.
    I highly doubt any of these springs go through the type of testing that Toyota did on their shit springs!
    If you really want to know what is 'best' for your ride, get all 3 and test them ON YOUR UNIQUE SET UP and sell the ones that aren't as good for what ever reason. When you test them - make sure you put them through their paces in the type of driving you like to do. More than likely, one set will stand above the others.
    :END RANT:
  12. Jul 26, 2010 at 12:10 PM
    mnudo200827
    Michael
    Corona, CA
    would the all pro 62" baja leafs be what you are talking about. Isnt there some tyoe of brackets you have to frabricate to fit those? And what is the lift on those if you know?
  13. Jul 26, 2010 at 12:19 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I chose "other" because we used these for dessert for years, worked WAY better than any of the options you said, my mom loves them:
    Sweet Dessert Pack
    Unless maybe you're like, gonna serve Yule Log or something, I guess then you could bring it in like a roasted pig on a spit sorta, that would be pretty cool if you got the alcans. Maybe you have really heavy cake.
    :D Just messing with you.
  14. Jul 26, 2010 at 12:21 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    i don't think any of what you listed would taste good at all. :) try a slice of pie or cheesecake.
  15. Jul 26, 2010 at 12:25 PM
    mnudo200827
    Michael
    Corona, CA
    ya ya, i know i spelt desert wrong in the title:eek:
  16. Jul 26, 2010 at 12:26 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    lol, i'm just playing
  17. Jul 26, 2010 at 12:27 PM
    mnudo200827
    Michael
    Corona, CA
    haha ya i know you are:D
  18. Jul 26, 2010 at 12:39 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    If you're running in the desert, to do it right you'll want to go with a spring-under setup. This will involve new brackets, welding, shock hoops or a bed cage, the right shocks, etc. Moving the leaf pack under the axle frees up tons of space above the axle, allowing the suspension to compress move before parts start to interfere with each other (leafs hitting the frame, etc.)
    As for the springs themselves...
    Deaver makes the leafs for the Giant 64" and the DMZ 62" spring-under kits.
    The Engage spring-under kit uses the All-Pro Baja Leafs. (from what I've read)
    Alcan makes a nice product but you'll still need to get brackets.
    From what I've seen, the Engage setup will give you the most lift. Most spring-under kits ride near stock height or about an inch higher.
  19. Jul 26, 2010 at 12:55 PM
    mnudo200827
    Michael
    Corona, CA
    is the deaver F67 a over or under setup?
  20. Jul 26, 2010 at 4:29 PM
    HBMurphy
    Paul
    So California Coast
    None
    Sweet!!!
