Better gas mileage with different octane?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wasatchute, Feb 1, 2018.
  1. Feb 2, 2018 at 9:59 AM
    #61
    Snakedoctor
    Snakedoctor Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    But is it noticeable enough to justify the higher cost of premium?
    Timmcc02 likes this.
  2. Feb 2, 2018 at 10:41 AM
    #62
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    You still fail to acknowledge that the ecu ALSO knows what octane level its using and has set parameters to run that fuel at the correct timing that the software engineers already tested at when designing the truck.
    At low elevation it cannot safely run less than 87 without risk of detonation because it cannot retard the timing any less. It is at the bottom of the curve. Because the barometric pressure is significantly lower when you’re up higher (less air to breathe, and you need air+fuel for combustion), it is perfectly happy to use 85 octane with a similar timing that sea level trucks will use for 87. If you put in 87 at high elevation, it will still run fine because it will advance the timing similarly to how it would for you if you put 89 in. It will be down on power either way, but that’s what you get for having less air in the cylinder.
    The octane and engine timing balances out with lower pressure, which is literally what us elevation guys have been saying this whole time.
  3. Feb 2, 2018 at 10:43 AM
    #63
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    All this bickering about gas and octanes.
    As long as you have corn juice in the gas ALL calculations are off the window. Want LEADed pure gas? All Pipers and Cessna use leaded gas (aviation fuel) since with the (commercial) gas would not take off...
  4. Feb 2, 2018 at 10:52 AM
    #64
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I love these threads where posters think they are smarter than the guys who designed the vehicle....
  5. Feb 2, 2018 at 10:53 AM
    #65
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    So the article from the Denver post that you linked is wrong that the logic once used for older cars no longer applies to modern engines?
  6. Feb 2, 2018 at 10:58 AM
    #66
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    AVGAS does not really work correctly in old cars that require Leaded Fuels because the Vapor Pressure is different.
  7. Feb 2, 2018 at 4:22 PM
    #67
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    I'll fill up on premium before a snowstorm, figure it gets me a little more driving before i have to fill up, little less chance of getting stranded without gas. Pretty scientific, huh? :D
