Better MPG in warm weather?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by James_Bond, Mar 31, 2016.
  1. Mar 31, 2016 at 6:45 PM
    James_Bond
    James_Bond [OP] Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Some say it's true others can't tell the difference.
    But has anyone with the new Taco notice an increase in MPG while driving in warmer weather?
    I can say this is true in my case. I drove from southern California to Denver and noticed a hit on MPG average. From 75 degrees to 40 degrees I saw a drop of 2 MPG(24 Hwy MPG vs 22 Hwy MPG). Other factors like altitude may also play a fact.
  2. Mar 31, 2016 at 6:50 PM
    eon_blue
    Azusa, CA
    Altitude definitely plays a factor, probably the primary reason you noticed the change. Engines are less efficient at higher altitudes, and the difference between socal and denver is considerable.
  3. Mar 31, 2016 at 7:01 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Air is more dense when it's cold. The air to fuel ratio changes. Your computer then remaps the fuel injection and it will increase the amount of fuel injected. Thus impacting the MPG
    Kyitty and ecoterragaia like this.
  4. Mar 31, 2016 at 7:04 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
  5. Mar 31, 2016 at 7:08 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Plus it's uphill
  6. Mar 31, 2016 at 7:10 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    To be honest you may notice a difference more then others because of your Atkinson cycle type motor. Your intake valve is being held open longer then others, thus your forcing more of that cold dense air into the cylinders through lower then atmospheric pressure, and given the altitude your running at, that would make allot of sense to see a change in MPG.
  7. Mar 31, 2016 at 7:11 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I have a 2nd gen 2015. Air temp seems to play a large role in my fuel mileage. I saw a sudden 2-3MPG drop once winter and the winter blend gas hit the market fall of 2015. I also tend to get better fuel economy on my drive home than my drive to work (according to a live MPG estimate on my Ultra Gauge). Granted that 20 mile commute covers a 400ft elevation difference.
  8. Mar 31, 2016 at 7:17 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Winter blend gas affects mileage too but I don't know the details or when the change occurs. Fill up before last my mileage increased 1 mpg, however I wasn't driving the same routes so that's inconclusive.
    Arailt likes this.
  9. Mar 31, 2016 at 7:21 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    It was pretty obvious here. My gas station suddenly had a "Contains Ethanol" sticker on their pump that was NEVER there before. That tank of gas, and every one after it, I saw a consistent 2-3MPG loss. That same week is when 'winter' hit. We've not had consistent temps of more than 45F since.
  10. Mar 31, 2016 at 7:59 PM
    ecoterragaia
    Central Virginia
    I am not sure that it matters, both Atkinson "simulator" and Otto cycle are sucking the same air and fuel with similar environmental variables mostly based on driver input. Atkinson keeps intake valve open longer in order to push air and fuel back out of the cylinder during the compression stroke, thus only using enough energy during the power stroke to overcome frictional/mass losses and a little more to keep the truck moving. The OP's fuel efficiency hit is likely due to colder temps (denser air=more oxygen=more fuel injected to achieve proper stoichiometric ratio for efficient combustion), and possibly winter blend fuel (i.e. higher butane levels=less energy per volume of fuel) still being used in the area due to colder climate.
  11. Mar 31, 2016 at 8:07 PM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    I disagree. The intake valve staying open longer is going to suck in more air, more colder denser air. So if it's sucking in more dense air the truck is going to compensate more and throw off his mpg even more then a engine without. So I believe it does directly apply.
    James_Bond[OP] likes this.
  12. Mar 31, 2016 at 8:33 PM
    ecoterragaia
    Central Virginia
    Otto cycle engines pull in air until the piston hits bottom, then the intake valves shut and the piston moves upward into the compression stroke. Atkinson simulator pulls in air until the piston hits bottom, and the intake valves stay open while the piston is moving upward into the compression stroke, which forces air/fuel back out through the intake valve opening. Sometime during the compression stroke the intake valves close. This means less air/fuel is used, with the endgame being better fuel efficiency with less power produced. In case you're wondering where the air/fuel that is forced back out of the intake valves goes, it's been explained that it is timed so that another cylinder sharing the same intake manifold is pulling in air/fuel while the original is pushing it out.
    Not trying to be argumentative, maybe I just don't understand what you're saying.
  13. Mar 31, 2016 at 8:42 PM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    I fully understand the Atkinson cycle. Also don't mean to be argumentative, i don't think we are going to find a happy medium here, so all i was trying to get by was, that a you can't be surprised when a engine specifically designed for more efficient use of air gets worse gas milage when that air density / temp is changed.
    ecoterragaia[QUOTED] likes this.
  14. Mar 31, 2016 at 8:46 PM
    ecoterragaia
    Central Virginia
    Agreed :cheers:
    2stroketrush[QUOTED] likes this.
  15. Mar 31, 2016 at 8:49 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Yep ethanol blends reduce the efficiency thus lower mileage for the sake of emissions
