Better MPG
Discussion in '1st Gen. Tacomas (1995-2004)' started by P_Tree, Aug 26, 2010.
  1. Aug 26, 2010 at 4:43 PM
    P_Tree
    P_Tree [OP] Well-Known Member
    Tyler
    Beavercreek, Oregon
    1995 1/2 Tacoma
    Custom plate bumper Trail Gear sliders/rear bumper Magnaflow exhuast Warn M8000 Winch Rocklights 8" Hella Fogs Cargo Bed Basket Tint 35 12.5 KM2s SAS Swap CB and PA Hids 8k highs and lows Fogs 12 inch alpine sub Spec intake Blacked out Grill, Emblems, etc...
    I drive a 1995 1/2 tacoma 2.7 and im getting about 16 mpg. Anyone know how to get better than that?
  2. Aug 26, 2010 at 4:44 PM
    Snowmang
    Snowmang Well-Known Member
    Jacob
    09 grey sport
    Exhaust billy 5100's smoked headlights and taillights.
    drive slower
  3. Aug 26, 2010 at 4:46 PM
    P_Tree
    Tyler
    Beavercreek, Oregon
    1995 1/2 Tacoma
    cant go any slower.
  4. Aug 26, 2010 at 4:50 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    your o2 sensor MAY be fucked..
  5. Aug 26, 2010 at 4:52 PM
    P_Tree
    Tyler
    Beavercreek, Oregon
    1995 1/2 Tacoma
    i was wondering that. would cold air intaking it help much?
  6. Aug 26, 2010 at 7:35 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    also clean your throttle body. I'll bet its pretty dirty!
    Do the deck plate mod. It will cost you under $10 and you will see results!
  7. Aug 26, 2010 at 7:47 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Depending on your setup, 16 mpg really is about right for stop and go driving. I get about that in town but my truck is on the heavy side. On the highways, I get about 20-25mpg avg over about 15 miles, depending on other factors (how I'm driving, traffic, speed, etc).
    If you're really concerned about your mpg, you need to get yourself a scangauge and configure it for your tire size so you can get accurate mpg readings. After watching it, you'll be able to see how even tiny changes in how you work the pedal, etc make a huge difference in how much fuel is consumed.
  8. Aug 26, 2010 at 7:59 PM
    Madjik_Man
    Colorado Front Range
    Lower rpms
    And use cruise control as much as possible while in the highest gear possible.
    The last two tanks of gas I've been hypermileaging like this and have seen an extra 3 mpg compared to what I used to average.
  9. Aug 26, 2010 at 8:36 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    don't use your clutch to slow down, use your 'breaks'...i love when people spell brakes like that.
  10. Aug 26, 2010 at 11:35 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    only drive around town where it is flat. and put skinny tires in motion with slow accel.
  11. Aug 27, 2010 at 5:42 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    thats really low for a 2.7. when was the last time you did a tune up on the motor?
  12. Oct 16, 2010 at 1:45 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I recently purchased a 00 2.7L Tacoma Prerunner and noticed its sucking down considerable more fuel then i would have expected for a 4 cyl. I would estimate 17-18 mpg. From what ive seen on the diagrams there is the post cat o2 sensor, as well as a pre cat A/F sensor. Would one contribute to the efficiency problem more then the other?
  13. Oct 16, 2010 at 9:30 PM
    RideFast
    Jesse
    Tacoma
    Sounds about right mpg, u have a truck that is as big as a 4x4 v6 and pushin it with a 4 banger. Dont take me wrong i am not bashin, i have owned 2.7L and i love that motor! I used to get 17-18 on a reg cab 4x4 2.7L
    Maybe think about a spark plug and wire set change. U might pick up some lost power by changin those worn parts.
    How are your driving habits, driving habits always reflect mpg.
  14. Oct 16, 2010 at 10:42 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    run some sea foam, check your sensors. clean that throttle body. do the deckplate mod (does a good job) skinny tiers help. but they dont up it like crazy. ive swaped mine out it didnt change it but 5 miles a tank.
  15. Oct 16, 2010 at 10:48 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    The one before the cat. It sends the feedback to the ecm so it can regulate how much gas is injected. If it's messed up you could be running rich. Though your mileage says your probably not. That's about right for that engine and 4x4.
    The second sensor is for emissions purposes. EDIT: Therefore, it does not change the fuel efficiency at all, regardless of it's condition.
    Interesting choice of username.
  16. Oct 18, 2010 at 4:11 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Good info. Had my cat coverter stolen at work, crackheads sawzall'd it off right after the front sensor and back sensor, leaving both sensors intact but taking converter and flanges. Fixed it with a "test" pipe and clamps,lol. Funny thing is it pulls the hills better but the mileage stayed the same (about 17). Engine light is on all the time now,,until I pull a steep hill and let it get hot, then the light goes off,,once crested and cooling down a bit, light comes back on.
    Plugs look fine,,light tan color,,so we will let it ride.
    I run a bottle of Lucas inj cleaner thru there probably about 2-3 times a year
    would like to get that engine light off tho'. guess I have to scratch and dig the grain bulb? out of the dash or ??.
  17. Oct 18, 2010 at 6:29 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    When I bought my truck, it was pretty obvious the owner didnt take too much care of his engine. I started out with 14.5-15MPGs (3.4L V6).
    -First I replaced my spark plugs and saw a huge difference in smooth idle and more power (didnt calc MGPs). – This, by far, made the biggest noticeable difference! Highly recommended you check your spark plugs!
    -Next I Sea Foamed the hell out of the engine, added seafoam to the gass (to clean injectors), cleaned the throtle body, and replaced my MAF sensor – Also added a noticeable change to performance
    -Lastly I added the deck plate mod and drop in K&N air filter. Didn’t notice any big difference when testing on either city or high way (except noise when I got on the gas).
    Current MPG's is 18.5 avg, 22 highway (without Deck Plate Mod as I keep it closed - Waiting for K&N to dirty up a bit b/f opening). About what you would expect from the factory (purchased with 92K miles, currently has 96k).
  18. Oct 18, 2010 at 10:25 AM
    Leadgolem
    Greg
    Littleton, CO
    Your probably throwing codes saying your cat is f'ed over. I think that is a good excuse to get a highflow cat. :)
    I wouldn't remove the bulb for the check engine light. That's just going to hide other problems if/when you have them.
    There is something called a sensor simulator for the rear o2 sensor. It would probably stop you from throwing the code about the cat, but I'm not sure if it's legal or not. Probably not though.
  19. Oct 18, 2010 at 10:34 AM
    40950
    CR, WA
    stock
  20. Oct 18, 2010 at 10:55 AM
    Leadgolem
    Greg
    Littleton, CO
