Better on road handling/cornering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SaltyPizza, Aug 16, 2020.
  1. Aug 16, 2020 at 9:33 PM
    SaltyPizza
    SaltyPizza [OP] Member
    ‘20 Tacoma TRD pro
    AnyTruckWillDo likes this.
  2. Aug 16, 2020 at 9:37 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    That’s a first. Should’ve gotten a sport instead. Good luck
    ORtoCOTaco likes this.
  3. Aug 16, 2020 at 10:00 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Not sure without changing your suspension out. That’s why I got an off-road to lift and change shocks. Someone will chime in with good info I’m sure.
    Good Luck
  4. Aug 16, 2020 at 10:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Rear sway bar 100% Tacomas don't have one, it makes a big difference.
    Tunrdas only recently started installing them on their TRD Sport models.
    It's less useful for offroading, but if offramps are the issue, the hellwig is a great start.
    toofast4u752 likes this.
  5. Aug 16, 2020 at 10:22 PM
    outlaw_taco
    outlaw_taco Well-Known Member
    Houston
    2021 moon rock
    You
    can’t
    be
    serious
  6. Aug 16, 2020 at 10:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome first poster! The Pro suspension is soft and not what you want for an on-road speedster, at all. Swaybars will help with body roll but not really fix the suspension issue. If you are serious, I'd suggest looking at the TRD Baja suspension instead, which is the firmest suspension ever offered by TRD on a Tacoma designed for high speed. Paired with the progressive AAL in the rear it handles much more like a dialed in performance street vehicle than a soft off road truck, but also still excels off road. I wheel my truck, but also want precision sporty handling on road paired with an over driven supercharger and the Baja setup has been fantastic. It would seem somewhat like blasphemy to take off your brand new Pro Fox suspension though to swap to a 2nd Gen TRD performance Bilstien suspension, but on the upside if you take it off to sell you'll get good money for it.
    https://www.tacomaworld.com/threads/selecting-a-mild-lift-trd-baja-tx-pro-icon-aal.385619/
  7. Aug 16, 2020 at 11:25 PM
    FattyKrack
    FattyKrack Well-Known Member
    Santa Cruz
    2019 TRD Pro
    There's a thread on here showcasing lowered tacomas sooooo
    a400ryan and SaltyPizza[OP] like this.
  8. Aug 21, 2020 at 12:27 AM
    AnyTruckWillDo
    AnyTruckWillDo Tacolytic
    2018 Taco crewcab sr5
    Vinyl wrapped fender flares, Diamondback tonneau, anytime front/rear camera, Off Camber Fabrication rear bumper, fiber glass hood with scoops and vents.
    Just installed the Hellwig 7744 this past Sunday same day OP started this thread. Kevin from Hellwig is super helpful, however Hellwig products are ok because they mass produce for hundreds of other vehicles so the hardwares are not specific only to Tacoma’s. I actually added more reinforcements to their L bracket (for endlink) to frame design. At softest setting I still definitively notice improvement in cornering and high speed stability. Others in this thread suggested different (stiffer) suspension, but I prefer the simple sway bar option which is cheaper and can be disconnected and zip tied the day before an off road expedition.
  9. Aug 21, 2020 at 12:35 AM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Stock SR suspension will get you exactly what you describe.
  10. Aug 21, 2020 at 4:59 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Despite what a lot of fanboys think, the Pro suspension sucks...
    The Sport. OR, SR suspensions are just hot boiled garbage.
    Until I switched suspensions I did not believe how bad they really were.
    If you want a ride that is like a Caddie on straight runs, but to be able to corner like a Porsche,
    then look at the Bilistein 8112/8100 combo.
    The limitation to my cornering speeds now is my tires...
    tall sidewallls do not like hard cornering...
    Truck now handles better than a Raptor and ZR2 both on and off road.
    I may not be able to out accelerate anybody but I sure can corner and slalom better than them. Even cars....
    Oh and they are fantastic off-road too. Better than Kings by a long shot!
    Sell the Pro suspension and get the 8112's, you will NOT be disappointed.
    Even holding them side by side you will see they are a LOT beefier and they have a lot more tech and engineering inside them than the Fox's .
    Did a LOT of riding around on different suspensions (King, Fox 2.5's etc) before I bought these and would do it again.
    There is no sway bar on the Taco , but the rear leaf hangers are weak as crap,
    look into purchasing and installing something like Hammer Hangers or BAMF hangers.
    You'll find that the Taco will need a lot more engine to need a sway bar after thses are installed.
  11. Aug 21, 2020 at 10:50 AM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    Op, you should have a chat with @subrat
    tonered likes this.
  12. Aug 21, 2020 at 10:57 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I cant tell if your trolling or not...
  13. Aug 21, 2020 at 11:11 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I noticed a little bit of improvement in fast cornering after installing my sumo springs (612-40s). I have a cap and some extra weight and it reduced the feel from excessive leaf spring compression on sharper turns with dips etc.
    a400ryan likes this.
  14. Aug 21, 2020 at 11:13 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I have a Sport, rides like a truck...no issues.
    Bleep100 and a400ryan like this.
  15. Aug 21, 2020 at 11:15 AM
    angerbot
    angerbot Well-Known Member
    Quality Friday post
  16. Aug 21, 2020 at 11:16 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Let me understand this...you paid for the Pro and you want it to ride like the Sport because you have no intention of taking it off road? Is that right? Get ready for a Friday afternoon roasting sir.
    SaltyPizza[OP] likes this.
  17. Aug 21, 2020 at 11:27 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Here's the thing from a Sport guy with the sway bar delete (SBD). I did this for both on and off road comfort and capability.
    ----> Embrace the handling. <----
    Feel the roll and the suspension loading up. A wicked stiff truck is not like a proper car. For the truck, the CG is a lot higher (approx above the wheels) which causes some really uncomfortable feelings when super stiff. In a car, the CG is down around axle level. The lateral motions are not causing a large amount of side loads plus roll forces.
    With the high CG, you will not be gaining much more traction from the inside tires. Just a fact. Your cornering is not going to be greatly improved unless you go very far down the rabbit hole. Woe be you and esp your passengers when you hit an uneven bump. I wholey approve @daks 's idea, but those Billys are eye-watering pricey, for a reason. Also, add in the cost of an eventual rebuild . . .
    Now, if you really want to go down the handling route, drop it like a proper sport truck. That is really the only way to do it right and not lose your bank account.
  18. Aug 21, 2020 at 11:50 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    I pulled my sway as well and I like it. It really helps soften bumps while not changing dipping at stops and it was way nicer on tougher trails. Mine is staying off. Not really relevant to the OP, but I agree with you.
    tonered[QUOTED] likes this.
  19. Aug 21, 2020 at 11:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    Thanks!
    That is where I came from, and also nasty looks from my wife when rolling over our driveway curb.
    rsimi72 likes this.
  20. Aug 21, 2020 at 12:02 PM
    su.b.rat
    su.b.rat broken truck
    this is real info right here, OP. these guys know what they're talking about. but i also wouldn't be satisfied with just some Bilsteins.
    if you know what you have and enhance it, and then learn how to drive it right, this truck is unbelievably agile on road and super quick, but you'll need to have the MT truck to get that performance. weight shifting and chassis control comes largely from the throttle on this truck, and if you have an AT you're not in the game.
    the 7744 Hellwig is a good start but the truck needs much much more to excel. if you want to discuss further pm me. i have a lot to say about it, because my plan for the truck has become a huge success for me and it's as engaging as a high performance kart. very hard to drive well but very quick and rewarding. believe when i say that the BS spewed around here regarding what is possible with this truck is proven incorrect in my experience, every day every drive.
