Better ride: 886 coils or spacers?
Discussion in 'Suspension' started by hockeypoor, Feb 2, 2009.
  1. Feb 2, 2009 at 10:59 AM
    hockeypoor
    hockeypoor [OP] Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    Ok so I was on the Toytec site and I see that the 3in spacer kit and the coil only kit (886) are the same price.
    Question:
    1) Which 1 will ride better?
    2) Will they both need new upper control arms?
    will be all ON ROAD driving. Will have 17X9 wheels and 265/70/r17 tires
    Thanks in advance.
  2. Feb 2, 2009 at 11:07 AM
    hsc001
    hsc001 Well-Known Member
    laurel, Maryland
    08 TRD off road lifted
    BHLM, 3" toytec coilovers, blacked out billet grille, hella 500's behind grille, volant CAI, Dual flowmasters 40's, HID, DTLT
    i would say there both going to ride about the same. The spacer is just going to compress your original spring for the extra three inches, and the coil is going to be longer and stiffer the stock to give you the three inches, especialy the 886's. No you dont need upper control arms for any of the two lifts, it is recomended for correct alignment thou. Im running 884 coils with no after market upper control arms and im doing fine. Going to get some soon. Others will chim in soon for things i missed. or might not be 100% correct on. But my advice would be to save up the money and get the toytec coilovers.
  3. Feb 2, 2009 at 11:08 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    No need for 886s if you don't have a heavy front bumper... :D
  4. Feb 2, 2009 at 11:21 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I went with the spacers, some say the ride is harsh. That was somewhat true, but then I added new UCA's, rides nice now, you can even ask some of the people (hoosiertaco) who rode in it.
    Going to be switching in the near future, going to be running a heavy front bumper.
  5. Feb 2, 2009 at 11:27 AM
    hockeypoor
    I thought I needed the 886 because i have DCLB. I don't think the spacers compress the stock springs. I believe them to mount on top of the strut housing and just relocate the spring 3in lower. Is that right?
  6. Feb 2, 2009 at 11:31 AM
    longbow
    Bill
    Indiana
    Here is a pic, you can pretty much see what is going on.
  7. Feb 2, 2009 at 11:38 AM
    hockeypoor
    What UCA's are the best to run. I see the ones on TOYTEC for like 429. Are they as good as the Total Chaos?
  8. Feb 2, 2009 at 11:44 AM
    longbow
    Bill
    Indiana
    Don't really know....I posted on it awhile back, alot of people said to go with Total Chaos so I did.
    Shop cut me a deal since they did everything else. I will say however to look into everything. I know I would most likely go a different route, but it was my first lift and you live and learn.
  9. Feb 2, 2009 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    885's are for Double cabs. Thats what Im running
    The Light raceing arms correct for alignment, but they have a ball joint, where as the TC's have a uniball. Uniballs give more strength and travel. Also, many people have had issues with the LR's.
