Better ride quality?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dustinclm, Oct 12, 2010.
  1. Oct 12, 2010 at 2:36 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    I have a 3" lift on my 01 tacoma for the last 40,000 miles or so and i was wondering today what were some good shocks to go with if i wanted to see if i could get a little smoother ride...i dont do intense off roading anymore but still do some light stuff and also haul my boat...currently have stock front shock and skyjacker hydro 7000 in the rear...is there anything out there that may give a slightly better ride quality?
  2. Oct 12, 2010 at 4:33 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I think I can probably speak for a majority here when I say Bilstein 5100's.
  3. Oct 12, 2010 at 6:21 PM
    dustinclm
    Thibodaux, La
    yeah thats what im hearing...about what to the go for, pricewise? i havent had a chance to research them yet. will they raise the front on inch or am i making that up? (bc i would prefer that actually)
  4. Oct 12, 2010 at 6:49 PM
    dustinclm
    Thibodaux, La
    would you know the part number for the shocks i would need?
  5. Oct 12, 2010 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is that Tough Country lift made up of spacers in the front?
    If you have a 3" spacer lift in front, can't recommend the 5100s unless you install to the 0 setting or remove the lift spacer in favor of using the 5100 lift settings.
    What is lifting the back, blocks with stock leaf springs or replacement leaf packs?
  6. Oct 12, 2010 at 9:56 PM
    dustinclm
    Thibodaux, La
    yeah its the tuff country with front spacers and blocks in the rear...after researching im going to remove the spacers and let the shocks give me the lift as long as i dont lose any height in the front.
