Better suspension than stock, but not a lift?
Discussion in 'Suspension' started by JCBigler, Jun 24, 2012.
  1. Jun 24, 2012 at 1:21 PM
    JCBigler
    JCBigler [OP] Well-Known Member
    Chouteau, OK
    Silver 2010 4WD, SR5, DC, TRD OR w/tow
    stock, Yaesu FT-8800R with a Maldol EX-107B, rear breather mod
    Hey guys, I have a kind of odd question. Been thinking about upgrades to my truck and all, and I don't know that I want or will need a lift. But I would like a suspension that is better than the stock suspension, i.e. more durable/capable etc... but isn't necessarily a lift.
    I didn't really see any threads addressing this, so I though I'd post it.
    If I'm not looking for a lift, what should I replace the stock suspension with that will be more durable for light to moderate off roading etc?
    I have the rear leaf TSB on my 2010 DCSB TRD Off Road, 4wd.
  2. Jun 24, 2012 at 1:22 PM
    BulletToothTony
    BulletToothTony TTC #0001 Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Bilstien 5100's at all four corners and set the front ones at zero :D
    Now thread :locked:
  3. Jun 24, 2012 at 1:23 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Could replace shocks with 5100's all the way around. They ride a lot smoother. You could just set the fronts enough to level it out with the rear with the TSB.
  4. Jun 24, 2012 at 1:24 PM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    Yeah, I would say 5100s, or I believe some of the coilovers can be run at zero lift.
  5. Jun 24, 2012 at 1:55 PM
    DevL
    DevL Well-Known Member
    Does nothing for your springs though. If you run coilovers set to stock, custom Deaver or Alcan pack and shocks to match the coilivers you will far exceed the capabilities of stock springs and 5100.
  6. Jun 24, 2012 at 1:56 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Yep. 5100's
  7. Jun 24, 2012 at 1:57 PM
    BulletToothTony
    That'd be an expensive ass way to go about getting a better ride and dont the deaver and alcan packs raise the rear end 3 inches? He will have hella serious rake.
  8. Jun 24, 2012 at 2:13 PM
    JCBigler
    Chouteau, OK
    So I'm looking for these Bilstein 5100 shocks with my stock coils? And if I set the adjustment at 0, then I wouldn't have to mess with anything else in the suspension system, correct?
  9. Jun 24, 2012 at 2:24 PM
    BulletToothTony
    That or order from DownSouthMotorsports they have discounts for TW members and free shipping too just FYI
  10. Jun 24, 2012 at 2:46 PM
    Tacoma T
    Tacoma T New Member
    Central, South Tennessee
    08 PreRunner SR5
    Factory
    ^^this is what I want to do.
    I am suspecting that this would require a new alignment also, right?
  11. Jun 24, 2012 at 2:50 PM
    BulletToothTony
    yes any time you mess with your suspension (lift lower etc) you need to do an alignment to be safe
  12. Jun 24, 2012 at 4:05 PM
    DevL
    No they are however high you make them... note the word "custom" in the description... as in made to order to the height you specify.
  13. Jun 24, 2012 at 4:11 PM
    DevL
    As I stated earlier... 5100 are not the answer. You said you wanted a a mote capable and durable suspension. No capabilities will be improved (towing ability, load control, srticulation, better handling, etc.) nor will durability be improved (less sagging over time, etc) so do you care about capability or just ride comfort?
  14. Jun 24, 2012 at 10:13 PM
    JCBigler
    Chouteau, OK
    Capability.
    Maybe I'm not asking the right question.
    So far when I've been off roading, the suspension seems to bounce around too much. I get too much vertical travel when driving over various obstacles. Thus far, I've mainly been riding some wooded trails and though the rock bed of rivers when they are low, so there's a lot of rough travel conditions and it feels like maybe the suspension is too soft?
    I'm not interested, at this point, in getting bigger tires, which as I understand it is the reason to get a lift. So I'm not interested in the lift, but rather a more capable and more durable suspension (i.e. one that will take more abuse and not wear out as fast).
  15. Jun 24, 2012 at 10:55 PM
    DevL
    By vertical travel do you mean belly flopping onto your skid or bouncing up?
  16. Jun 24, 2012 at 11:04 PM
    white toy taco
    white toy taco 505 Member
    Gian
    Albuquerque, NM
    02 4X4 Taco SR5 TRD V6
    All-Pro tube bumper, 5100's at middle setting w/OME 881's, rebuilt leafs w/ 2 chevy leafs, 265/75/16 Km2's, CloudyFab sliders, 6000k HID headlights (35w), 16" LED light bar,100w KC Daylighters,
    get the 5100's. i almost guarantee that if you keep up with tacomaworld, you will want to get bigger tires and a lift (just read my sig below the post). this way you can get good quality shocks and also have the ability of lifting the front if you ever decide it
  17. Jun 24, 2012 at 11:10 PM
    JCBigler
    Chouteau, OK
    Belly flopping onto the skid plate under the engine, yes. Like the shocks aren't taking the load as well as they should. And I'm not riding over terrain that I consider to be all that tough and not very fast, like 5 or 6mph usually. It migth be worth noting that I usually seems to feel like it's a problem in the front suspension, and not so much in the rear suspension...Maybe?
    Thought it didn't happen here, this is the kind of terrain that I was driving on, which is a combination of river bed rock and loose rock in a river bed that is mostly dry (it fills with water during heavy rain and we don't get to ride on it, obviously).
    This is looking down the river bed
  18. Jun 24, 2012 at 11:47 PM
    DevL
    Digressive gets firmer with increases in speed, it just starts higher (usually) and it is less steep than progressive at high shaft speeeds. Higher speeds still result in more resistance... just a lot less at higher shaft speeds than progressive. It is not actually less resistance than lower speeds though. It ramps up then levels out. In this case I dont think 5100s are the answer (at least not 100%). I think you need stiffer springs. All the weight on a Tacoma is up front. The front compresses WAY more easily than the rear. Even the progressive coils on the Off Road are not stiff enough and IMO a little lift to gain clearance, even with stock tires, is a good thing. Consider 884 coils. Lift is minimal and it will 100% solve you issues with added stiffness. It does not look funny with stock tires IMO. I run 885 coils and they are just longer for higher ride height. Still rode great with stock tires... good enough for my rear to be far exceeded by my front. New shocks wont change height either. Just realize that more damping ability means less on road ride comfort/softness. Choose your shocks wisely.
    There are three things that absorb compression impacts... shock valving, spring stiffness, and distance. New shocks and springs solves all three.
  19. Jun 25, 2012 at 5:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 SCREW
    F-250 Land Yacht Mod
    883's or Eibach coils could also be used and would be a shorter lift. Both would give around 1.5" of lift up front and both are stiffer coils that stock (Eibachs being the stiffer of the two).
