Better Tie Rod Ends
Discussion in 'Suspension' started by SCM Taco, Jan 6, 2012.
  1. Jan 6, 2012 at 7:58 PM
    SCM Taco
    SCM Taco [OP] SCM Taco
    08 PreRunner
    King Shock Coilovers, Camburg Upper A-Arm, Camburg 4" Spindles, N-Fab Light Bar, Afe Cold Air Intake
    I have a 2008 Tacoma Pre-Runner and i put the camburg upper control arm and 4" lift spindles on, but having trouble with tie rod ends!! Need something a little longer and stronger. Alignment guy says the stock tie rod ends are a little too short and may cause problems! Suggestions would be very helpful
  2. Jan 6, 2012 at 8:09 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Go to RockAuto.com and check out the Moog tie rod ends. Thats what I went with when I put my spindles on and they are greasable. And welcome to TW!!!
  3. Jan 8, 2012 at 8:12 AM
    SCM Taco
    08 PreRunner
    Cool thanks for the help!!
  4. Mar 29, 2012 at 10:46 PM
    MountainMan777
    MountainMan777 Well-Known Member
    CA
    07 TRD Offroad Prerunner
    I have a 2007 tacoma prerunner and i just put foc coilovers adjusted to 2.5" and Total Chaos UCAs on it and no one has been able to align it, its toed out like crazy and can barely drive it. My alignment guy said I need shorter tie rod ends because the tie rods are adjusted all the way and there is no thread left and its still toed out because of the lift. Anybody know where i can find some? or what else could be causing this problems?
  5. Mar 30, 2012 at 9:11 AM
    SCM Taco
    08 PreRunner
    I ran into the same probelm. You can have it alined to make it drivable by having the camber set all the way forward to align it. thats what i did and ive been driving it like that for 6 months. but i am in the proccess of fixing the problem you actually need a longer set of tie rod ends. The kit i am looking at runs $500. Its from All-Pro Offroad. Couldnt find it on website so posted a link with it.
    http://www.ttora.com/forum/showthread.php?t=113890
  6. Apr 2, 2012 at 6:06 PM
    MountainMan777
    CA
    Longer tie rod ends huh? will that allow me to pull the toe in more than i would with the stock ones?
