Better to route the Diff Breather to Tail Light or Gas Cap Area?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma’20, Oct 20, 2020.
  1. Oct 20, 2020 at 4:05 PM
    Tacoma’20
    Tacoma’20 [OP] Well-Known Member
    Wincent
    Southern California
    2020 Silver Sky Metallic TRD O.R. 2wd
    Should I route the Diff Breather to Tail Light or Gas Cap Area? Is one better than the other? Pros and cons?
  2. Oct 20, 2020 at 4:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Makes no difference
    Skydvrr and Hobbs like this.
  3. Oct 20, 2020 at 4:14 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    If you do the gas cap area make sure you check before you drill. Someone ended up drilling into the filler neck.
    I went gas cap and I just make sure it's still good every time i get gas
  4. Oct 20, 2020 at 5:36 PM
    Scarab
    Scarab Well-Known Member
    2017 White Tacoma TRD Pro
    I went behind the tail light and required no drilling.
    rnish likes this.
  5. Oct 20, 2020 at 5:37 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Try the small cubby that no one uses.
  6. Oct 20, 2020 at 5:39 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I routed mine into my cubby as well, enlarged one of the existing drain holes.
    Don't forget your front diff trans and transfer case breathers either.
  7. Oct 20, 2020 at 5:43 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I almost did the cubby but decided on the gas cap.
    Also the front diff trans and t case are fairly high up
    Skydvrr likes this.
  8. Oct 20, 2020 at 5:52 PM
    Key-Rei
    Key
    Florida
    I went ahead and extended those all further up into the engine bay anyway, the rear can be a little lower as you should create a bow wake in water but I wanted the front stuff higher and it was easy and quick.
    Dirk Diggler likes this.
  9. Oct 20, 2020 at 9:36 PM
    hotrodder636
    hotrodder636 Well-Known Member
    2020 Tacoma TRD Pro (MGM)
    Are there kits out there for this or is it homemade stuff?
  10. Oct 20, 2020 at 9:45 PM
    Key-Rei
    Key
    Florida
    It's one barbed nipple, and one barbed breather cap from the dealer, a few feat of 3/8 gas hose from the auto parts store, and a handful of zipties.
    I imagine there's "kits" but they're not cost effective.
    ARB has a really fancy breather kit I know of but I laughed when I saw the price, it's like $100 for something that can be done for Free-Fiddy.
    hotrodder636[QUOTED] likes this.
  11. Oct 20, 2020 at 9:47 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You don’t need one. I’ve done enough water crossings that it’s a moot mod
  12. Oct 20, 2020 at 10:09 PM
    Key-Rei
    Key
    Florida
    Water crossing is one thing, being stuck sitting in water for a few minutes is entirely another.
    It's cheap insurance for if you ever do something dumb you don't have to pay as badly for it.
    hotrodder636 likes this.
  13. Oct 21, 2020 at 5:08 AM
    JoeCOVA
    Joe
    Colorado Springs
    It’s not, but you can keep telling yourself that if it makes you feel better.
    If someone is that paranoid about getting stuck in a river so long that the breather fails then they probably shouldn’t be out there to begin with.
    Minutes you say? Try days.
    VeeSix likes this.
