Better transmission for 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROMYER8313, Oct 13, 2020.
  1. Oct 13, 2020 at 10:24 PM
    ROMYER8313
    ROMYER8313 [OP] Active Member
    robert
    medford oregon
    08 sport package
    supercharger, 3inch lift, Doug thorley long tube headers and Magnaflow pro series off road exhaust. urd 2.55 pulley, ucon ems, upgraded urd fuel pump, urd seventh injector system, 61lb mulit-fuel fuel injectors, and AFE cai.
    I have a 2008 double cab sport addition that has a urd stage 3 supercharger setup with a built transmission from ipt. I am wondering if there is a beefier transmission that would fit onto my truck that could withstand over 400hp and not break. I broke my factory transmission and had to have it rebuild by ipt. then the third gear and reverse went bad and I replaced that and it seems to run fine now, but I want something that can stand the high hp and heavier towing.
  2. Oct 14, 2020 at 12:08 AM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Maybe call jasper? See what they can do.
  3. Oct 14, 2020 at 12:35 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    There's a company I can't think of the name for right now that makes a T56 swap kit for the Tacoma 4.0, (URD?) if you need to stay 4WD though you might have to get a divorced Atlas transfer case.
    A build T56 should be good to go up to 700hp, I don't think you can get a 1GR to that level without blowing it up.
    Have you removed your clutch accumulator valve?
    EdgemanVA likes this.
  4. Oct 14, 2020 at 1:05 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is this an Automatic or Manual?
    There is at least 1 person on here with a built 4.0 with over 400 hp.
  5. Oct 14, 2020 at 1:09 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    its a 2008, so i guess by dumb luck (maybe planned) you have not blown up that 1GR, you will blow up that 1GR if you push it any higher.
    that said, OEM 5 speed trans should handle 400HP just fine if well maintained and running a cooler.
    what are you doing with this truck?
    Accipiter13 and TnShooter like this.
  6. Oct 14, 2020 at 1:23 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    you could find a special order 1978 CJ-7 (only year offered) with a 401, T-18 trans, Dana 300 xcase and dana 44 axles and do a swap? make as much HP as you want, wont break sh*t, lol!
  7. Oct 14, 2020 at 7:36 AM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Buy a dodge 2500
  8. Oct 14, 2020 at 7:57 AM
    gearcruncher
    Canadain bumper technician
    The A750E series 5 speed transmission that you have in your truck is rather stout for the Tacoma .
    The same transmission use to come from factory in the Tundra .
    This being said , were you servicing your transmission on a regular basis ?
    Do you have an aftercooler suitable for assisting with the extra heat generated from towing and being supercharged ?
    Are you monitoring your transmission temps ?
    I do not beleive the aftermarket makes an adapter kit to fit a General motors 4L80E in place behind a Tacoma 4 liter engine .
    Thats usually the go to transmission for higher horsepower swaps but the 4L80E is far less reliable than your factory transmission .
    MattCowsmasher likes this.
  9. Oct 14, 2020 at 8:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is pretty accurate. www.lceperformance.com has or had the adapter plate. Been used on a Tacoma on this site.
  10. Oct 14, 2020 at 8:18 AM
    gearcruncher
  11. Oct 14, 2020 at 8:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Raybestos used to also offer upgraded clutch packs for the A750E. @Lucario Runner has those in his transmission with the upgraded valve body.
    TnShooter likes this.
  12. Oct 14, 2020 at 8:50 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    The 750F is a tank. I’d be putting the biggest derale cooler on that I could and then not worry about it.
