BEW TDI TACOMA SWAP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wachterhunter, Jan 29, 2024.
  1. Jan 29, 2024 at 8:52 AM
    Wachterhunter
    Wachterhunter [OP] New Member
    1999 Toyota Tacoma 3.4
    Hello, just looking for some help here with my swap! I have a bew tdi engine and I have the oem ac compressor but it fits up on the alternator side of the motor. I know the bhw compressor sits turbo side so that would work out much better for running ac lines and what not. I was thinking I could switch ac compressors and use the rad fan clutch from the bhw as a placeholder for the bew ac compressor. If anyone knows or has done this already any help is appreciated!
    I can understand how this may be a little confusing so if you have questions I’m more than happy to explain further! Thanks in advance
  2. Jan 29, 2024 at 4:40 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Seems like this is a TDI-based question and not a Tacoma question. You might have better luck on a TDI-based forum. Very few people have a TDI swapped Tacoma so finding info will be hard.
    RattleTractor likes this.
