Beware changing LSD lube!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, May 17, 2010.
  1. May 29, 2010 at 7:04 PM
    #181
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    well hope this helps.. i had my rear end changed on my truck for a major shudder. dealer filled the new rear with synthetic lsd fluid and i had a shutter with the new rear end aswell. the dealership had the toyota engineer get in on it and he said that these rear lsd on our trucks are not liking the synthetic fluid and toyota knows about this. they drained and refilled with regular gear oil and a tube of lsd additive and so far so good.
  2. May 29, 2010 at 9:23 PM
    #182
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats exactly what I have discovered.
  3. May 30, 2010 at 1:02 PM
    #183
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Okay just got back from camping and put almost 300 miles on my truck. Did a lot of turning from going up and down the mountain and no chatter from the rear differential!!!:D I am happy with what I used. Again for the people that didnt know, I used Valvoline 80W-90 regular gear oil for lsd's and a 4oz. bottle of Redline friction modifier. After 300 miles and a lot of turning, so far so good.:thumbsup:
  4. May 31, 2010 at 9:47 AM
    #184
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Finally got the rear diff done today. The old stuff didn't look too bad. I could tell it was pink..... If you think gear oil smells nasty, that XL3 ford additive is even WORSE!!! OMG that stuff is horrible!!
    Hey WW Firefighter - you weren't kidding about the flowmaster exhaust. I didn't have a wrench big enough to get on the fill plug and I didn't have enough room to get a socket in there. I ended up jacking the truck up, putting the body/frame on jackstands and dropping the axle down to the floor. It was wide open at that point where I could get a socket on it and squirt the oil in.
    Drove 1/2 mile and heard 2 little 'whomp whomps' while making a right turn driving towards the empty parking lot where I did my 8's and circles. Didn't hear anything else after that. Crossing my fingers I won't hear anymore!
  5. May 31, 2010 at 10:21 AM
    #185
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah they should have designed the exhaust system a little bit different that way we could have changed the rear diff oil easier!!!:mad: I was lucky enough to get a socket in there but had to lift the exhaust a little at the same time to get it all the way on. But all-in-all, it wasnt to bad to change out.:rolleyes:
    Well hopefully you wont hear and chattering back there once everything settles in.;)
  6. May 31, 2010 at 10:23 AM
    #186
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep us posted :)
  7. Jun 5, 2010 at 5:41 PM
    #187
    rha009
    rha009 Member
    Little Rock
    08 Prerunner TRD Sport
    I just changed the differential fluid in my '08 TRD Sport (30k miles) today and it's got some chattering. I used 3 quarts of Valvoline 75w90 for limited slip from Autozone and I also used "Champion" brand 4 oz lsd additive from O'Reilley (Autozone was out of their stuff).
    I did about 5 figure eights and it was still chattering pretty good. I've driven about 15 miles since it's been changed.
    Does it take time for the new oil to get "worn in", should I try a different additive, or should I just drain it and try a different type of oil and additive?
    Help anybody?
  8. Jun 5, 2010 at 6:12 PM
    #188
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. The oil doesnt ned to be worn in. Maybe try a different addative first.
  9. Jun 5, 2010 at 9:40 PM
    #189
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Did you use the full 4 ozs?
  10. Jun 7, 2010 at 6:28 AM
    #190
    rha009
    rha009 Member
    Little Rock
    Yep.
    I'm going to try to get a different LSD additive today to add to it to see if that helps. I'll update with the results tonight or tomorrow morning.
  11. Jun 7, 2010 at 6:31 AM
    #191
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So I managed to clock 500 miles on Mobil Delvac and 5 oz of GM additive.
    No Issues.... :D baby is quiet and cool.
    If it is stays like that, next change in 50 k :goingcrazy:
  12. Jun 7, 2010 at 7:26 AM
    #192
    Janster
    Jandy
    Lancaster, PA
    Updates:
    I did the oil change a week ago, did some 8's and circles that same day (Mobile 1 75W-90 w/ Ford XL3 modifier)
    After the truck sat overnight and I'd go to drive it each day, I'd get a 'rumble' the first 2 turns and that was it. It'd be fine the rest of the day/trips. Same thing each day it sat overnight. Rumble the first 2 turns....and fine after that.
    On Saturday, we took a 2 hour round trip (mostly highway miles). Truck sat overnight Saturday night and I went to work on Sunday. I didn't get any rumbles at all yesterday or today. Still crossing my fingers for the long term.
  13. Jun 7, 2010 at 1:00 PM
    #193
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well its been a few weeks since I swapped out mine with Valvoline 80W-90 limited-slip gear oil with 4oz.'s of Redline friction modifier and no chatters or rumbles so far.:rolleyes: Hopefully it stays that way.:eek::D
  14. Jun 8, 2010 at 6:12 AM
    #194
    rha009
    rha009 Member
    Little Rock
    Last night I added in the Motorcraft friction modifier that I picked up from the Ford dealership.
    A few rumbles when I first started, but now it appears to have mixed in and fixed my problem. Crossing my fingers that it doesn't chatter anymore!
    With that said, I would not recommend using the "Champion" brand friction modifier that O'Reilley sells, as it seems to not prevent chattering.
  15. Jun 9, 2010 at 11:25 AM
    #195
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I've got a couple of days of driving with the Redline under my belt and I must say there is indeed less noise. The temp gun mentioned earlier in this thread (from Amazon) has showed a consistent 6 degree drop in temp after my 20 mile commutes, so thats probably not showing a significant improvement, but still interesting.
  16. Jun 9, 2010 at 6:14 PM
    #196
    wlmuncy
    William
    Knoxville, TN
    Jack this again: We'll Toyota does not supply buildsheets, which is kind of lame, but I did get my answer. No LSD on my truck. So glad to not have the chirpiness others have.
    Dear Mr. Muncy,
    Thank you for contacting us.
    We appreciate your interest in properly maintaining your Tacoma.
    We have verified based off of your Tacoma's VIN that it is not equipped with Limited Slip.
    Thank you again for your inquiry.
    Sincerely,
    Thomas Morita
    Toyota Customer Experience Center Customer (Muncy)06/09/2010 04:42 PM Does my truck have a Limited Slip Differential? It appears no, but I want to make sure before I service the differential.
    Sent: Wed, June 9, 2010 7:16:31 PM
    Subject: Build Sheet [
    Recently you contacted Toyota. Below is a summary of your contact message and our response.
    Thank you for allowing us to be of service to you.
    SUBJECT
    Build Sheet
    DISCUSSION THREAD
    RESPONSE (TOM MORITA) 06/09/2010 04:16 PM
    Dear Muncy,
    We apologize build sheets are not available for our customers. However, based on your provided Vehicle Identification Number, 5TELU****************, we are able to pull from our records a list of factory and port installed equipment, which are as follows:
    50 State Emissions (FE) Factory
    SR5 Package #2: Remote Keyless Entry, Cruise Control, Variable Speed Wipers, Chrome Grille Surround & Rr Bumper, Color-Keyed Fr Bumper & Overfenders, Fog Lamps, Sliding Rr Window w/Privacy Glass, Metallic Tone Instr Panel Trim, Leather Strng Wheel & Shifter, Sunvisors w/Mirrors & Extenders, SR5 Badging (SL) Factory
    MECHANICAL & PERFORMANCE
    236HP 4.0L V6 DOHC 24V Engine w/VVT-i
    6-Speed Manual Transmission
    4WDemand 4x4 System w/ Electronically
    Controlled 2 Speed Transfer Case
    Coil Over Shock Double A-Arm Fr Susp
    Multi-Leaf Rr Suspension w/Staggered
    Outboard Mounted Shocks
    Front Stabilizer Bar
    Pwr Assisted Rack and Pinion Steering
    Pwr Assisted Fr Disc/Rr Drum Brakes
    16" Styled Steel Whls, P245/75R16 Tires
    SAFETY
    4 Wheel ABS w/Electronic Brakeforce
    Distribution (EBD) & Brake Assist (BA)
    Dr & Fr Pass Advanced Airbag System
    Dr & Fr Pass 3pt Seatbelts with
    Pretensioners & Force Limiters
    Rr 3pt Seatbelts & Adj Headrests
    CRS Lower (ISOFIX) & Top Tether Anchors
    Side Door Impact Beams
    Tire Pressure Monitoring System
    EXTERIOR
    Black Grille/Fr Bumper/Overfenders/
    Handles/Outside Mirrors
    Argent Grille Surround, Rear Bumper
    SMC Composite Inner Bed w/Steel Outer
    Panels, Removable Tailgate & Rail Caps
    Deck Rail System w/4 Adj Tie-Down Cleats
    COMFORT & CONVENIENCE
    Cloth Bucket Front Seats w/Pass-side
    Fold-flat, Driver-Side Lumbar Support,
    Adj Headrests & SR5 Fabric Trim
    60/40 Split Rr Bench w/Underseat & Rr
    Bulkhead Storage
    CFC-Free Air Conditioning
    Pwr Windows/Door Locks/Mirrors
    AM/FM/CD w/6 Speakers
    Tilt/Telescoping Steering Wheel
    Engine Immobilizer
    Cig Lighter+Aux Power Point
    3 Ctr/2 Rr Console Cup Holders
    LED-Illuminated Gauges
    Thank you for your inquiry.
  17. Jun 9, 2010 at 6:19 PM
    #197
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    So you are getting some chattering with the Redline?
  18. Jun 10, 2010 at 6:35 AM
    #198
    Airun
    Aaron
    Show Me State
    No chattering at all. The only sound now is when I first back out of garage onto sealed asphalt and make a moderately sharp turn to leave the driveway first thing in the morning. What I do here is a soft rub or hum sound which may be the worn out gy 245s. I've become so paranoid and oversensitive that I really feel this is nothing to worry about. I think the nature of an LSD mechanically is gonna cause some rub as the internal clutch mechanism attempts to distribute and balance some torque to both wheels. I think the Redline is the best so far of the 3 lube setups I've tried and I'm gonna stick with it. Tired of pissing away cash.
  19. Jun 10, 2010 at 6:57 AM
    #199
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Recap: I have Royal Purple in the diff, got some chattering, added some of this stuff and now finally good to go!!:)
  20. Jun 10, 2010 at 9:00 AM
    #200
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    I just got off the phone with the local toyota service guys. He told me that toyota has recently reformulated the LSD fluid. He quoted me $75.00/L.....not including labor....WTF. Has anybody else heard of this?
