Beware changing LSD lube!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, May 17, 2010.
  1. Jun 10, 2010 at 1:17 PM
    #201
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That will vary from dealer to dealer. My local dealer told me it'd cost $40 for the LSD rear oil change including labor (conventional oils & FM). My other dealer quoted me $60 for the same service (synthetic & FM).
    Try calling a different dealer and see what you get.
  2. Jun 10, 2010 at 1:25 PM
    #202
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    I am going to just use the dyno Valvoline 75-90, some trans-x addative and call it good :)
  3. Jun 11, 2010 at 5:47 AM
    #203
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Yeah I mentioned way back in this thread Joplin Mo dealer 62$ qt
  4. Jun 11, 2010 at 8:15 AM
    #204
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    Thats what I did and noise gone!! Drive great, and cheaper.... gotta love that
  5. Jun 14, 2010 at 7:23 AM
    #205
    Tom's Turf
    Tom's Turf Member
    Maryville, TN
    TRD Sport 4X4
    K&N drop in filter, Westin sidebars
    Changed to Amzoil 75/90 Severe Gear and added Amzoil LSD additive......no problem:thumbsup:
  6. Jun 14, 2010 at 7:48 AM
    #206
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    SWEET!!! I just need to get some...thanks AMSOIL Rules!
  7. Jun 14, 2010 at 8:15 AM
    #207
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Clutch packs don't produce metal shavings, its your gears wearing down :D
  8. Jul 6, 2010 at 8:21 AM
    #208
    Janster
    Jandy
    Lancaster, PA
    After about 1,000 miles (Mobile 1 75W-90 w/ Ford XL3 friction modifier) update:
    After the change - I was getting grumbles during the first few turns after the truck sat overnight. That was it. The rest of the day it was fine. It eventually came down to only grumbling at the first LEFT turn. And now, it seems even that first left turn grumbles are fading away. I can hear it, but just barely. I roll down the windows & turn the radio off to listen...
    I'm hoping it was just a matter of time for things to work themselves in....
  9. Jul 6, 2010 at 8:27 AM
    #209
    BlueT
    NorthEast
    I am at almost 2K mark with Delvac and GM additive, so far no issues. I think once out of blue moon I get faint rumble but my engine tends to give the same amount of vibe so not clear on that. Otherwise its all good (to the point that I almost forgot i supposed to listen :D )
  10. Jul 9, 2010 at 8:09 AM
    #210
    Janster
    Jandy
    Lancaster, PA
    So, mine is still grumbling slightly in the left turns. I sent an e-mail to the Toyota dealership whom I respect (and bought the truck from). I honestly wasn't expecting an answer. I specifically explained about my situation, the oils I used, and the fact that I called them for suggestions on the modifier along with - 'the manual isn't clear enough' about what needs to be used, etc. I gave him my VIN number also.
    Another reason I did this - was to get some 'documentation'. If my rear diff has a problem in the future, I have a better chance at fighting it IF they won't cover it under warrantee.
    So, for what its worth.....this is from the Service Manager (Carl Crone) at New Holland Toyota:
    JANDY, MY UNDERSTANDING IS THAT WE USE A 75W- 90 FLUID ALONG WITH A AFTERMARKET ADDITIVE OR FORD ADDITIVE ,WE HAVE HAD TO ADD 2 BOTTLES OF ADDITIVE AT TIMES TO CORRECT A SHUDDER SO I WOULD TRY THAT AT THIS POINT. IM NOT SURE IF THE MOBILE 1 IS A PROBLEM , I DON’T THINK SO BUT I WOULD ADD ANOTHER BOTTLE BEFORE CHANGING THE FLUID. LET ME KNOW HOW YOU MAKE OUT . THANKS CARL SVC. MNGR.
    So, I'm off to the Ford Dealership to get another bottle of XL3. It's a no wonder Toyota got rid of the mechanical LSD's in these trucks. It shouldn't be this difficult to change the oil. AGain, this is the reason why I respect this dealership. They actually respond and give me 'believable' information in return.
  11. Jul 9, 2010 at 8:12 AM
    #211
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have tried the extra addative with the Mobil 1 to no avail. Seems the Mobil 1 isnt liked by this rear diff. Dino oil of the correct weight, along with the recomended addative works fine.
  12. Jul 9, 2010 at 8:19 AM
    #212
    Dave333
    Dave333 Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    Amsoil as well 75W90 with their additive in the Taco, the Mustang and the Charger SRT8, never had any issue's.
  13. Jul 9, 2010 at 8:22 AM
    #213
    Janster
    Jandy
    Lancaster, PA
    I've used Amsoil Severe Gear (no extra additive) in our Corvette w/ LSD without any issues.
    It's a crap shoot...... Did you use Severe Gear? That's already got additives in it.
    I wanted to get Amsoil, but I wasn't about to pay another $20 just to renew my membership.
  14. Jul 9, 2010 at 12:37 PM
    #214
    Dave333
    Dave
    Loganville
    I used the 75W90 Severe Gear with the small bottle of Amsoil Slip Lock. I've used this combo on the Mustang right after changing the rear gearing to 3.73, on the Charger and on the Tacoma. Alot of the guys on the Mustang forums stated that if you're changing the fluid to go ahead and add the Slip Lock. So far I haven't had any problems. Charger has 20k miles since the change, Mustang 10k and the Tacoma 40k.
  15. Jul 14, 2010 at 6:16 AM
    #215
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Just put in the Amsoil last night witht the Amsoil slip lock...so far so good! No chatter for the first 50 miles! I'll be changing it out in say...75k miles :)
  16. Jul 25, 2010 at 3:32 PM
    #216
    tacomajaybee
    tacomajaybee Member
    Josh
    Black Hills
    05 Tacoma TRD Sport
    Man i wish i woulda read the forums before changing my Rear Differential.
    After changing the original gear oil out and putting in Mobil1 75-90 Sythetic i got a vibrating noise when accelerating from stopping points. Jumped on the forums and walla, found out that the Tacomas dont like synthetic gear oil in the REARs.
    Went down and bought the Lucas 80-90 and a Friction modifier from Autozone and noise is gone.
    My front and transfer were still looking new so i didn't worry about changing those at the moment, but i did read that the synthetic has no problems in the front or transfer.
    Gotta love the forums.
    JayBee
  17. Aug 5, 2010 at 9:36 AM
    #217
    BlueT
    NorthEast
    Update:
    So I am at 2500 mile mark with Delvac and two GM bottles of additive.
    LSD diff quiet and smooth:thumbsup::burnrubber:.
    Number of miles until next change
    997,500 :D
  18. Aug 5, 2010 at 9:59 AM
    #218
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Update: Everything is smooth with the Amsoil. ;)
  19. Aug 5, 2010 at 10:22 AM
    #219
    Janster
    Jandy
    Lancaster, PA
    Seems like the consensus is....to use a double dose of friction modifiers.
    If the oil you use already has friction modifiers in it, then adding another bottle of a friction modifier seems to be the trick.
    I did my change 2,000 miles ago with MObile 1 and XL3. I added a 2nd bottle of XL3 about 1,000 miles ago and everything has been fine since.
  20. Aug 5, 2010 at 11:31 AM
    #220
    BlueT
    NorthEast
    yep apparently that's what we had been missing. 2 years after Toyota stopped selling LSD trucks we finally got it :D
