Beware changing LSD lube!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, May 17, 2010.
  1. Oct 15, 2010 at 1:25 PM
    #221
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I'm about to do the 30k maintenance on my '09 sport. Read through this whole thread and was getting worried since I was about to use Amsoil severe gear 75/90 to do my rear diff. Used it in my '01 with no problems but that was an open diff. Then I started thinking: Toyota switched to electronic LSD in '09 didn't they? Does that mean I have open gears and there is no need for concern about LSD additives? ELSD means the slip is controlled electronically from outside the gear box right?
    JAD4x4SA likes this.
  2. Oct 15, 2010 at 3:39 PM
    #222
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Correct, you dont have to worry about additive. :)
  3. Oct 15, 2010 at 8:01 PM
    #223
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I see this thread has been around a while..
    When I had my diff fluids changed by the Toyota dealer last week, they said they are no longer using Toyota brand diff fluid because it costs so much, they are using Ford brand.. I hope it doesn't cause any problems....
  4. Oct 16, 2010 at 4:51 AM
    #224
    KeithB
    Keith
    Cheshire, CT
    Does that mean I will be fine with synthetic? I called my dealership and asked the service dept. They said to use 80W/90 and a tube of LSD additive. I asked if I really needed the additive even though it was ELSD and not mechanical. I have a feeling they really don't know either. They usually don't. I mean, I knew more about the truck and options than they did when I bought the truck.
  5. Oct 16, 2010 at 5:48 AM
    #225
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Ok .. I had my dealer do the 30 k service.. I have 4x4 with Elect diff lock... They said it doesn't need change because there isn't a Limited Slip in the rear end.. I assume that is true... is it?
  6. Oct 16, 2010 at 5:52 AM
    #226
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I would just go with Amsoil or Redline and see how it does. If it is noisy or vibrates then add some friction modifier, but probably not necessary with a brake actuated diff rather than mechanical clutch LSD.
  7. Oct 16, 2010 at 5:56 AM
    #227
    Airun
    Aaron
    Show Me State
    yeah with only 30k I would assume your fine. if your concerned or if you've dunked it in some deep water you could drain some and just have a look. you could probably even used a syringe type setup and open the check plug and with a short piece of tubing attached draw some out and send a sample to Blackstone for analysis.
  8. Oct 16, 2010 at 5:58 AM
    #228
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You still need to change the diff oil regardless of what kind of differential you have. Open diff, LSD, locker.....you still need to change the oil.
    The dealer told you that it didn't need changed ??
    If you have a mechanical LSD - it needs friction modifier. All other diffs do not need friction modifier.
  9. Oct 16, 2010 at 6:41 AM
    #229
    BlueT
    NorthEast
    Dealer probably misunderstood year and they think you have mechanical LSD. Thats all. You can use pretty much any oil you want.
    So any synthetic you want. :) and no additive unless you want to add some..
  10. Oct 16, 2010 at 2:40 PM
    #230
    KeithB
    Keith
    Cheshire, CT
    Awesome - that's what I thought. Thanks. BTW - BlueT, how's it going? Do you remember me from NTC. Red '01 tacoma - live in Cheshire. The '01 is gone now, traded it for the '09. You still wheel with NTC? Do you still have the LC, 1st gen tacoma and 2nd gen tacoma?
  11. Oct 16, 2010 at 3:29 PM
    #231
    BlueT
    NorthEast
    :D
    yep still with NTC and still rolling LC . It purrs like kitten, With 180k miles engine sounds better then 2gen truck. :cool:
    BTW if you need help just stop by ...
  12. Oct 18, 2010 at 5:48 AM
    #232
    KeithB
    Keith
    Cheshire, CT
    OK, I've called a half dozen toyota dealers in the area and they all say you still need to add the friction modifier even for E-LSD. Some seem to know what they were talking about and others not so much but not a single one said you don't need it. I think I might just go with Valvoline 80W-90 with the additive and skip the Amsoil for the rear just to be sure. Got about 400 miles to go before the service - so next weekend I guess.
  13. Oct 18, 2010 at 6:21 AM
    #233
    BlueT
    NorthEast
    Its simple thing to check. Do you have a sticker on the rear diff that says "LSD oil only" if not then you dont have mechanical LSD. It also should be listed on the vehicle purchase sticker. If both dont have mechanical LSD listed then you can use whatever oil you want.
    If you still not sure stop by my place on Sat and we will check.:proposetoast:
  14. Oct 18, 2010 at 7:57 AM
    #234
    ec8
    ec8 Newby
    Stuart
    I've used Redline 75W90 without adding any additional friction modifiers and have had no issues. I did this in both my '06 Tacoma TRD Sport and my wife's '05 4Runner both with the LSD sticker on the pumpkin. The Redline description states: "Contains additional friction modifiers for suitablity with clutch-type limited slip differentials - for most LSDs, no additional friction modifiers are required"
    I bought a bottle of their friction modifier but did not have to use it on either vehicle as they both run great without it. Been about 1500 miles on both and been quiet and smooth so far.
  15. Oct 18, 2010 at 8:02 AM
    #235
    Janster
    Jandy
    Lancaster, PA
    You do not need friction modifier for the AUTO LSD.
    How exactly did you ask them (in words) and who did you ask?
    Call them back and ask a TECH. Not the first person you talk to on the phone. Not the Service writer. Not the Service Rep, Not the Service Manager. ASK A TECH
    Make sure you fully explain to them exactly what you have. If they need - give them your VIN number.
  16. Oct 18, 2010 at 4:35 PM
    #236
    nighthawk87
    nighthawk87 Well-Known Member
    You can add I with friction mod even in non LSD without a problem so be safe
  17. Oct 19, 2010 at 9:41 AM
    #237
    Airun
    Aaron
    Show Me State
    Just a thought: I know I've read remarks earlier in this thread indicating that the friction modifier increases lubricity. Do we know for sure if this is the case? A clutch-type mechanism needs friction to work properly. Is it possible that synth lubes are too slick and the additive is to promote friction, ie decrease lubricity slightly so the clutches can grab properly when needed? I realize I am most likely wrong on this issue, has anybody done any research on this subject?
  18. Oct 19, 2010 at 11:23 AM
    #238
    Janster
    Jandy
    Lancaster, PA
    Friction modifier is a SLIP agent. It promotes slippage. Without it, there's TOO MUCH friction and why it chatters when turning.
    When both wheels are spinning at the same rate/speed, the clutches ARE grabbing already. Its when you make a turn, they need that friction modifier to allow them to SLIP (or stop grabbing) while in the turn. Obviously, you can make the turns...but the clutch continues to grab slightly while you make a turn. The friction modifier allows it to slip.
  19. Oct 19, 2010 at 5:34 PM
    #239
    KeithB
    Keith
    Cheshire, CT
    So what's the difference between mechanical LSD and electronic LSD? The way I understand it, mechanical has clutches inside the differential gear housing that come in contact with the gear oil and electronic uses sensors that measure wheel spin which in turn controls braking at the wheels. If that's correct, does that mean there are no clutches in the gear box for electronic LSD? Shouldn't matter whether the oil is synthetic or dino or has the additive or not, right?
  20. Oct 19, 2010 at 6:12 PM
    #240
    Airun
    Aaron
    Show Me State
    great explanation Jan, thats basically what I figured. even with the Redline and extra additive I get a trace amount of groan when I first take off, so I was entertaining the possibility that the modifier caused stickage instead of slippage. the sound is so minimal that I'm sure its not unhealthy, just being paranoid I guess. I have entertained possibly trying some Amsoil while I'm pissing away cash for lube, but I probably hold off for quite a while.
