Beware changing LSD lube!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, May 17, 2010.
  1. Jun 16, 2012 at 10:23 PM
    #261
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    It's about 75.00 a quart
  2. Jun 16, 2012 at 11:09 PM
    #262
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
  3. Jun 17, 2012 at 8:46 AM
    #263
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    hell thats a bargain. send me 3!
  4. Jun 17, 2012 at 8:50 AM
    #264
    Airun
    Aaron
    Show Me State
    Good question. Then again, who cares anyway?
  5. Jun 17, 2012 at 6:15 PM
    #265
    tx novice
    Ron
    OAHU
    Well...kinda late to ask, but I thought "bump" meant it was a good topic that you could easily find for later viewing?:confused:
  6. Sep 24, 2012 at 8:24 PM
    #266
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So after reading this thread, is it safe to say?
    dino oil - add 4oz LSD additive
    synthetic oil - add 8oz LSD additive
    Sound right?
  7. Sep 25, 2012 at 4:12 AM
    #267
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not necessarily.....
    If you're using synthetic, put 4oz in to start with. Do some tight 8 circles and drive around for a few days. If your rear-end is chattering or rumbling, then add another bottle.
  8. Sep 26, 2012 at 8:44 AM
    #268
    replica9000
    2019 T4R ORP
    Thanks for the info. Looks like between the diffs, transfer case, and the tranny, I'll be buying 8 quarts of gear oil. Time for some OT at work...
  9. Sep 26, 2012 at 10:04 AM
    #269
    Janster
    Jandy
    Lancaster, PA
    Naaaaaa, just few less cigarettes and beers this week!
  10. Sep 26, 2012 at 10:28 AM
    #270
    replica9000
    2019 T4R ORP
    I was planning on getting Royal Purple Max-Gear 75W90. It's $20.99 a quart at my local Advanced Auto. 20.99 x 8 + 6.25% tax = $178.42. Royal Purple seems the least favorable synthetic here, but that was before we figured out to add up to 8oz of LSD additive.
  11. Dec 22, 2019 at 1:20 PM
    #271
    TacosorTaquitos
    TacosorTaquitos New Member
    Lane
    2007 v6 4.0 TRD OFFROAD
    Fog anytime
    I used Supertech full synthetic , and added Lube Gard limited slip supplement, in the past I used Mobil 1 with hypoid/LS already in....Didnt work shuddered like crazy , Used Redline , U name it......This Supertech is fkn awesome for the price...Now its smooth and silky like your mommas satin panties......The Lube Gard, "yes its spelled that way" is 7.50 at Oreillys , made with( Synthetic Wax Ester ). Hope this saved you all some money and solved some issues...
    Airun[OP] likes this.
  12. Dec 22, 2019 at 8:03 PM
    #272
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Seeing the price of the oil, almost more economical to convert to a TruTrac diff.
    knottyrope likes this.
  13. Dec 22, 2019 at 8:45 PM
    #273
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Almost 200 dollars every 30k miles. That's insane.
    Ditto. Go get a tru trac.
