Beware changing LSD lube!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, May 17, 2010.
  1. May 27, 2010 at 5:20 PM
    #161
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Copy that! Sounds like a plan!!;)
  2. May 27, 2010 at 5:30 PM
    #162
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I would try adding BG LSII. It is a great product and would probably help. Also a cheap fix for about $20.00
    http://www.bgprod.com/products/driveline.html
    You usually cannot find it on the shelves of most auto part stores. I know Napa has it.
    In my opinion royal purple is the best gear oil out there.
  3. May 27, 2010 at 5:54 PM
    #163
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Synthetic is fine for the front. Any GM type friction modifier should work well.
  4. May 27, 2010 at 5:55 PM
    #164
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...The Valvoline stuff caused chattering, so I added the CRC friction modifier. I'll see if it helped tomarrow.
  5. May 27, 2010 at 6:00 PM
    #165
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    So I have not yet been able to separate myself from this thread yet but can you damage the lsd by adding too much of the friction modifier? Is there such thing as "to much of a good thing"? I did not have a chance to swap mine out today but did check it last night and the current fluid looks new from just checking it through the fill plug with my finger. Last question does anyone know how much a new fill plug is?
    The head on mine is starting to round off a little and I might as well replace it before it strips.
  6. May 27, 2010 at 6:01 PM
    #166
    Redgrom
    Brent
    san clemente
    Never mind my last post, looks like I need to use the additive.
  7. May 27, 2010 at 6:04 PM
    #167
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    From what I have heard, too much LS addative, and the diff will slip more. It will be more "open".
  8. May 27, 2010 at 6:13 PM
    #168
    Redgrom
    Brent
    san clemente
    Thanks for the reply, looks like I will be adding the additive when I get around to it this weekend. I am sure I will check back too see how yours turned out Chris before I do anything.... Is the crc additive a 4oz bottle?
  9. May 27, 2010 at 6:14 PM
    #169
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  10. May 27, 2010 at 6:29 PM
    #170
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay so it seems like we are all in test mode right now for the stuff we put it.:cool: Like I said, I will be driving a couple hundred miles this weekend so I'll let you guys know. Hey chris, when does it chatter? Driving straight, on turns, or always?:confused:
  11. May 27, 2010 at 6:30 PM
    #171
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only when turning.
  12. May 27, 2010 at 6:31 PM
    #172
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay I'll keep my ear out for it on turns.;)
  13. May 27, 2010 at 8:14 PM
    #173
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Nice I will be doing swap this weekend. Delvac (non-lsd, extended life) + GM factory additive. I searched bunch of forums and this setup had worked for everybody from Porsche guys, Corvettes, Camaros, BMW's to GM cars. We will see how that plays out for us but all others seem to had new style ceramic friction clutchpacks so maybe thats the trick its correct additive that is designed for those clutch packs and Synthethic oil with out other LSD additive.
  14. May 28, 2010 at 5:44 AM
    #174
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    After checking this post, i went and check for the LSD sticker. It appears that either the previous owner bought an undercoating package or painted the entire frame, differentials, etc. So there is no sticker for me to find. My question is can I contact Toyota and get the original buildsheet for my truck to determine if it has the LSD or if it has an open differential. Sorry OP to jack this thread but I need to do a fluid change in the next few months and don't want to jack this up.
  15. May 28, 2010 at 5:55 AM
    #175
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    they might be able to, but there are a couple other ways too if they can't.
    you could also do a burnout and see if you leave one or two black marks. Two=LSD One=Open
    Chock the front tires. Jack up the rear of the vehicle with the tires off the ground. Put tranny in neutral. Rotate one of the rear tires forward. Watch what the other rear tire does. If it: Spins forward=LSD Spins backwards=Open
  16. May 28, 2010 at 7:12 AM
    #176
    afd23a
    The Dynamo of Dixie
    Stopped by the local dealer this morning to pick up some of the long-life coolant. Asked the guy at the parts counter what kind of gear oil they use for the limited slips. He said they use regular 75w with additive (they buy it by the barrel). I asked about synthetic and he said you could use it, but you'd still need the additive.
    I guess it just follows suit with what others have been told. :rolleyes:
  17. May 28, 2010 at 7:28 AM
    #177
    Fireguy67
    Fireguy67 Rebecca and Willow's Opa
    Klaus
    Maple Ridge, BC
    2013 4X4 4 door long bed TRD sport
    No mods- running boards, vent visors all around ,Leer XQ Cap, hood deflector,bed extender, OEM roof rack, Toyota bed mat.Nothing fancy!
    That's what I did under recommendation from a mechanic friend of mine-I filled it and forgot about it.
    I have a fiberglass topper on my toyota and have been helping a friend move over the last few weeks. With the weight of the topper as well as the stuff in the box when moving I estimate at times I was hauling about 650-700 lbs at different times over the last 30 days. No noise or problems encountered. For what its worth.....!
  18. May 28, 2010 at 7:41 AM
    #178
    BlueT
    NorthEast
    Thats exactly what I was told with addition that they buy additive from GM dealer:)
  19. May 29, 2010 at 2:33 PM
    #179
    BlueT
    NorthEast
    Ok I have 100 miles since the change to Delvac and GM additive in my LSD. So far its definetely very good and better then I though it would be. I still think there is faint chatter on hard acceleration during the sharp turn, but I can not hear anything just the feel (almost like stock radio bass playing). Then again I am expecting chatter so maybe my @$$ is just feeling something. I may add 1 oz of GM additive to take care even that but it looks like solutions is working. if that's it I am keeping Delvac in it :D
  20. May 29, 2010 at 3:12 PM
    #180
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Welp...I put about 300 miles on the truck, and have no chattering since I added 4 ozs. of the CRC LS addative, and the Valvoline 75-90 oil.
