Beware of WeatherTech Floor Liner
Discussion in 'Product Reviews' started by Julio27, Jan 6, 2011.
  1. Jan 6, 2011 at 9:56 AM
    Julio27
    Julio27 [OP] New Member
    I recently purchased WeatherTech floor liners for my 2009 4x4 access cab. The rear liner is not designed to fit a truck with a center console as the spacing in the center of the liner (the part that fits over the 'hump') is 14 inches, while Canadian Tacoma access cabs have a 10 inch spacing. Rightfully so, the website offers the following caveat:
    "Rear liner will not fit with optional center storage box/console."
    The problem here is, the center console is standard in Canada and the liner will not fit unless you are prepared to wipe the turkey off of your carving knife and get artistic. A telephone conversation with the customer service department yielded a refund offer which I turned down. I felt disappointed given the product's reputation and price ($240 tax in). I have never visited this forum before today and I'm posting here as a head's up to anyone else considering floor liners from WeatherTech.
  2. Jan 6, 2011 at 9:57 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  3. Jan 6, 2011 at 9:58 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I found the same thing. I just ended up trimming it and it works perfectly.
    Also, the driver's side front floor liner needs to be trimmed if you have a manual transmission.
    I agree, it is disappointing that they haven't molded for these two options yet. At this point, they probably never will.
  4. Jan 6, 2011 at 10:01 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I pulled out the box(4 screws) put the liner under it and put the box back and used 2 screws to hold it there. Some of the guys put holes in the liner to use all 4.
  5. Jan 6, 2011 at 10:03 AM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    You can un-bolt the console cut 2 holes where the bolts that held the console go through then put down the mat and reinstall console. Fits just fine without butchering the mat.
  6. Jan 6, 2011 at 10:06 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    I had the same issue with ym manual trans gunna trim it today! Been pissin me off! But the rear fits fine for me?
  7. Jan 6, 2011 at 1:51 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    Thanks for the heads up :).
    But from what I've seen, WeatherTech's are really nice liners. I know it sucks that it doesn't fit with your center console, but if the website CLEARLY warned you, and then WeatherTech STILL offers a full refund... How can you be disappointed in their "reputation and price"?
  8. Jan 6, 2011 at 1:53 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    when its not under water:D
  9. Jan 17, 2011 at 2:41 PM
    Plathora
    Plathora Member
    10 minutes to pull the box out, drill three holes in the mat, and re-install the box. Looks perfect. The one minor issue is you can't pull the mat out to clean easily, you would need to perform the same 10 minute procedure.
  10. Jan 17, 2011 at 3:01 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    I just ordered my WeatherTechs and will be drilling holes to fit the console over it. I don't think it will be a big deal cleaning the mat because no one will ever sit back there. If they do get dirty I'm sure it can easily be cleaned with a damp cloth.
