beware the block heater/motor swap ideas
Discussion in '1st Gen. Tacomas (1995-2004)' started by WhyteRaevin, Jul 10, 2010.
  1. Jul 10, 2010 at 11:44 AM
    WhyteRaevin
    WhyteRaevin [OP] Member
    Saskatchewan
    TRD XtraCab Step Side
    So I recently had some terrible luck.
    I was cruising down the highway when I start to hear a strange quiet ticking noise under my feet. I shut off the radio to listen and my check engine light comes on. I start pulling over and before I make it to the shoulder the tach drops to 0 and the engine quits. I pull over, jump out of the truck and pop the hood to a billowing cloud of white smoke in my face. My temperature gauge didn't tell me it was running hot, hmmm. I get the truck towed back home to my local mechanic and my buddy tells me the bolt holding my block heater in broke while I was cruising down the highway. When the block heater comes out all the coolant in the motor is pushed out the hole in about 5 to 10 seconds. He also tells me that the temp gauge will only read a liquid, so when all the liquid coolant comes out of the motor it will show it is WAY COOLER than it actually is while your motor cooks. It won't hold coolant because the heads are warped. Also there is a dirty misfire in at least one of the cylinders.
    My engine was overheated and cooked before I could even stop, less than 20 seconds.
    So now I need to decide if I want to rebuild the top end and hope there was no other damage.
    Or
    Get a motor from salvage with a questionable past.
    Or
    Put in something brand spanking new with all the trimmings.
    I want to stick with a 3.4 v6 like the truck came with. I need some input on what my best options are and where I can get a high-po 3.4 v6
  2. Jul 10, 2010 at 11:52 AM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    why not go with somethin bigger?
    4L v6 maybe? or a small v8?
  3. Jul 10, 2010 at 11:57 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2
  4. Jul 10, 2010 at 12:11 PM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    before you go swapping engines I would put a soft plug back in the hole, fill her up with coolant and see how it goes. I would think that there is a good possibility that it's fine. My old chevy would overheat and boil a few times during the summer and I would pull over, let it cool down, start it back up and it was fine. I know the 3.4 is prone to blowing head gaskets so maybe that is all you would end up needing. No need to replace the whole engine if it's not needed.
  5. Jul 10, 2010 at 12:12 PM
    WhyteRaevin
    Saskatchewan
    I want a 3.4 5VZ-FE v6 so I don't have to change anything engine control related.
    I took it to my mechanic and they went through it. It won't hold coolant because the heads are warped. Also there is a dirty misfire in at least one of the cylinders.
  6. Jul 10, 2010 at 1:54 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    No the 3.0l pre 1995 was prone to blowing head gaskets
  7. Jul 10, 2010 at 2:13 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I would try rebuild it. Check the lower block for cracks and warping.
  8. Jul 10, 2010 at 3:30 PM
    tinker_troy
    WA
    well damit all then
    opps, my bad
  9. Jul 10, 2010 at 4:21 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    x2 the V6 3.4L is a rock solid engine :D
