BF Goodrich TA K02 issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2017 TRD Sport, Jun 3, 2019.
  1. Jun 3, 2019 at 1:05 PM
    2017 TRD Sport
    2017 TRD Sport [OP] Active Member
    David
    2017 TRD Sport
    456 gears. OV tune. Lift. 285/70/17 tires
    I just had a new Jeep take off set of K02 in a 285-70-17. Tires took very little weight to balance. They seem to ride good with no vibration but they are doing something funny. Between 50-60 if I let go of steering wheel it will move back and forth about 1/8” - 1/4”. Any suggestions on what my problem could be? It does pull slightly to the right so not certain of alignment. Thanks for any help.
  2. Jun 3, 2019 at 1:06 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Your first step will be to get an alignment... After that... not sure.
  3. Jun 3, 2019 at 1:07 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    You can rotate wheels front to back and see if it continues
  4. Jun 3, 2019 at 1:59 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Alignment. How much lift?
    Surprised they needed "very little weight . . ."
    KO2's are famous for being a bit difficult to balance. DT got mine right every time, but they usually had to work at it.
    G.
    foodforbears likes this.
  5. Jun 3, 2019 at 2:13 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Try a few different roads and see what it does.
  6. Jun 3, 2019 at 2:16 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Do this first to see if the shimmy stays the same. That will help rule out balancing issues.
  7. Jun 3, 2019 at 2:40 PM
    2017 TRD Sport
    David
    2017 TRD Sport
    Thanks for all advice. I just rotated front to back. Will test drive again tomorrow. Does pull a little to the right so I do plan on getting that checked. Shop that installed wants to recheck balance Wednesday. I have 3” leveling kit up front with 1” tapered blocks on rear. I have about 18,000 miles with 285-70-17 Nitto Terra Grappler G2 and it drove close to perfect.
    DrewMaca likes this.
  8. Jun 3, 2019 at 2:57 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I had the same issue, steering wheel shake at around that speed and I ended up having a bad out of round tire. Replaced it and has been good ever since.
  9. Jun 3, 2019 at 4:12 PM
    jareebz
    jareebz Well-Known Member
    TX
    2019 TRDOR DCLB
    Could be why the Jeep owner got rid of them.
  10. Jun 3, 2019 at 6:07 PM
    2017 TRD Sport
    David
    2017 TRD Sport
    How did you find the out of round tire?
  11. Jun 3, 2019 at 6:11 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Rotate them left to right, and then front to rear. You will find the bad tire.
  12. Jun 3, 2019 at 6:13 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Trade ‘em for General Grabbers. Problem solved.
  13. Jun 3, 2019 at 8:59 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    synaps3, Mully, wolfman00 and 2 others like this.
  14. Jun 3, 2019 at 9:33 PM
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2021 Cement TRD OR DCSB
    Truxedo Pro X15 tonneau, front tinted windows
    Have you tried keeping your hand(s) on the wheel?
    General Grabber AT2 are awesome. Just got a set.
    Stocklocker likes this.
  15. Jun 3, 2019 at 9:49 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I have a shitload of old school weights and stick on weights on each wheel. Had to bring it to dealer twice for them to balance properly haha. So far no problems:fingerscrossed:, great all around tire
    My previous tires (duratracs) needed a shitload of weights too tho, mechanic even made a comment.
    Good luck!:cheers:
  16. Jun 3, 2019 at 11:45 PM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    I’m guessing your on lug centric wheels, not hub centric ..... try taking off the wheels and hand tighten them all the way down, then torque them to spec with the star pattern.....
    Mully likes this.
  17. Jun 4, 2019 at 3:36 AM
    2017 TRD Sport
    David
    2017 TRD Sport
    Yes I keep my hands on the wheel. Only did this checking how they drove. I do have hub centric wheels and I rotated them after this started. I draw them up even and then torque to 85’ lbs. thanks
  18. Jun 4, 2019 at 4:03 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    it's possible that your wheel bearings or steering rack needs some attention if the alignment and wheel balances are ok.
    it's stupid but like @fake4x4 said, try re-seating the lugs. if the shop just blasted the lugs on and didn't seat them, the wheel may be out of center from the hub slightly.
    fake4x4 likes this.
  19. Jun 4, 2019 at 6:06 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I vote for Grabbers too. :D
    Really though, I just wanted to add, make sure your surface is good with no ruts. Wide tires will find the grooves in the road better than a pizza cutter tire.
    Mugsy7 and Stocklocker like this.
  20. Jun 4, 2019 at 6:11 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Having owned a set of 265/40-17 General Grabber ATX for 10 Days: I’d say they are comparable to KO2s, which is a good thing. They ride comfortably, handle well, and look like a million bucks. They did well on a dirt road. The ATXs hum a little at speed, but not objectionably so. Haven’t had a chance to try them in foul weather yet.
    I’d put ATX on par with KO2s; and slightly above above Duratracs.
    Rob Daman and Stocklocker like this.
